anyone not reinstall swing arm gusset ? - Kawasaki ZX-10R.net
post #1 of 7 Old 07-30-2008, 10:05 AM Thread Starter
drkramm's Avatar
awhile ago i stripped out every bolt on the swingarm gusset ... was looking at taking that off cause i would liek to get to my exhaust valve but im hestiant casue i don't know if i could easy out it with out doing damamge .. question is anyone not running with this gusset in place have a proplem ? or is it there more for protection...
anyone ?
"Once you've tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been and there you long to return."
drkramm is offline
post #2 of 7 Old 07-30-2008, 10:26 AM
CMG
been running without one and don't see a diff ( lost the bolts in the garage). I read elsewhere that some racers take it off to get more flex.
You need to heat it to break up the threadlock. also tapping the L key in deep may help since most of the stripping happens on the outer parts.
HTH
CMG is offline
post #3 of 7 Old 07-30-2008, 11:29 AM Thread Starter
drkramm's Avatar
thanks when i get around to it there coming out
i tried everything but heat to get the bastards out
drkramm is offline
post #4 of 7 Old 08-08-2008, 02:19 AM
bugman53's Avatar
What? More flex? If you can actually explain why you would need more flex then i wonít flame you(there is one reason hint " controlled lateral flex" ).
Otherwise YOU NEED TO STOP GIVING OUT BAD information than you have no idea about. NO PUT THAT gusset back into the frame. I donít think that the frame will break if you leave it out but it is there for a reason so why would you wont to weaken the frame of your bike.
sorry but Iím tired of the squids on this board giving out bad info. GO BUY A GIXXER and be like all the other Suzuki riders than think GIZZXER is the right way to say gsx-r. And think that you can put a Cold air intake on a 600.
Sorry long night. Rant off.
High Velocity Cycles 2005 Ti ZX10R
Greeensboro NC
bugman53 is offline
post #5 of 7 Old 08-08-2008, 08:00 AM
greenman43's Avatar
Images: 33
anyone ?
I took mine off shortly after buying the bike. I've done 3 trackdays without, and assuming nothing weird happens when I go to slicks, it'll be staying off.
Cheers,
Brian
Do not walk behind me, for I may not be leading.
Do not walk in front of me, for I may not follow.
Do not walk alongside me, for the path may be narrow.
Just piss off and leave me alone.
greenman43 is offline
post #6 of 7 Old 08-08-2008, 10:56 AM
CMG
Originally Posted by bugman53 View Post
What? More flex? If you can actually explain why you would need more flex then i won’t flame you(there is one reason hint " controlled lateral flex" ).
Otherwise YOU NEED TO STOP GIVING OUT BAD information than you have no idea about. NO PUT THAT gusset back into the frame. I don’t think that the frame will break if you leave it out but it is there for a reason so why would you wont to weaken the frame of your bike.
sorry but I’m tired of the squids on this board giving out bad info. GO BUY A GIXXER and be like all the other Suzuki riders than think GIZZXER is the right way to say gsx-r. And think that you can put a Cold air intake on a 600.
Take a fuggin chill pill then re read my post, all it states is that there are some racers who do that and that is a fact you can check by using the search.
where do you get off calling people you don't know a Squid ???
lastly learn to spell better, can't believe you don't know how to spell a simple 4 letter word like WANT and THAT ( I'll let the grammer slide for now)
I'll buy a Gixxer if you go back to grade school.
Now go play in traffic.
CMG is offline
post #7 of 7 Old 08-18-2008, 12:15 AM
bugman53's Avatar
Sorry to insult you i, that was more of an overall rant then related to you.
Yea i cant spell worth crap.
I am owner of a motorcycle shop here in Greensboro and I am always fixing bikes because someone read it on the internet. It seems more often than not that it is the suzuki guys.
Unrelated example
It seems like the new thing to do is leave the rear axle loose because people think they get less bearing drag and their swing arm cracks and the bearing are spinning on the axle and eat it up.
Just a bunch of stuff like that. But that gusset is not that big of a deal.
But the reason people are taking it out is when the bike is laid over the suspension wants to move side to side(the bike is at a 45* angle and the suspension wants to move at the angle a small amount) and a little flex will give the bike better compliance with the track.
My point is unless you know for a good source what is does or have done it please don’t repeat things because you heard someone else did it.
Greeensboro NC
bugman53 is offline
06 swing arm gusset plate drkramm Performance and Tech 9 01-17-2010 01:40 AM
OEM Exhaust reinstall afskypilot Performance and Tech 2 03-28-2008 11:23 AM
Looking For 04-05 Swing Arm ogryders Wanted: Buy or Trade 3 03-24-2008 08:59 PM
OK..... 2nd gen swing arm on a 1st gen time..... garth285 The ZX-10R 4 08-20-2007 07:18 PM
04-05 10R swing arm TAI10 Wanted: Buy or Trade 0 05-16-2005 06:41 PM
