Anyone heard oh HP loss with extended swingarm? - Kawasaki ZX-10R.net
post #1 of 11 Old 08-02-2007, 10:21 PM Thread Starter
Speed Freak
garth285's Avatar
Hey guys well since I'm new in O-town around here I got to meet up with trey and a guy had a mobile dynojet 150.....Ive never had my bike on a dynojet before and was curious to see what kinda power it made and it wound up throwing down 160hp....
now for my mods it seemed kinda low and the guy said that he has seen 8-10hp loss with an extended swingarm???
anyone heard of that? I know on our factory pro it doesn't mater what you do from gear changes to swingarm length but just wondering.
P.S. Treys bike is pretty sick!!! lol
garth285 is offline
post #2 of 11 Old 08-02-2007, 10:27 PM
FAF
Rent this space
A lot depends on the motion ratio from axle centre line to shock travel, if you have a lot of squat in the bike then you are using power to keep the suspension compressed, bit like holding the brake on whilst you let out the clutch you stop forward motion but the bike sits down, let off the power and it rises again.
Reduce the squat and you get more tractive effort at the wheel.
FAF is offline
post #3 of 11 Old 08-02-2007, 10:30 PM
bluedevil's Avatar
Dang Trey you will hang out with anyone... j/m Garth
bluedevil is offline
post #4 of 11 Old 08-02-2007, 10:31 PM
FAF
Rent this space
Theres a good reason you see hardtail drag bikes, they let the tire do the work and not a shock.
FAF is offline
post #5 of 11 Old 08-02-2007, 10:34 PM
ZXTOM's Avatar
Yes you will see some power loss....
There is more load on the motor with a swing arm like that....
I use to race prohill climb and my race bikes all had extended swing arms.... Yes they lost quite a bit of power from stock form... kinda strange how that works...
“Accept the challenges so that you may feel the exhilaration of victory.” --General George S. Patton
ZXTOM is offline
post #6 of 11 Old 08-02-2007, 10:34 PM
inappropriate
hesaves0211's Avatar
Images: 67
i havent heard of the trig effecting the output on a dyno. but with the extended swing arm your leverage is dif which effects how your power delivery is read. my .02. i thought you were talking about puttin down 190hp!? hows that 16/40 set up, you ever consider 16/41?
1ST GEN-10R 234hp/[email protected], GT2871RS, cometic gasket, tial bov/ex wastegate, BEGI FMU, WALBRO fuel pump,falicon clutch basket,race pak clutch,200/50 pilot,yana-shiki levers,.net wristband, WEGO III,PC3,GPR damper,cbr cals/Galfer SS brake lines,gp shift,1/5 throttle, 2NDARIES REMOVED <<click for how-to, *R.I.P D.J 10 Apr 04*
hesaves0211 is offline
post #7 of 11 Old 08-02-2007, 10:36 PM Thread Starter
Speed Freak
garth285's Avatar
well i dont plan on leaving it extended for long anyways! lol I'm gunna try and find a real good swingarm for sale one of these days and swap it out....
well the bike still hauls major ass lol espically geared -1 front +1 rear and all the extra power...... I'll have to do a roll on with trey and compare :-D
I believe his bike made 155 on the same dyno
garth285 is offline
post #8 of 11 Old 08-02-2007, 10:39 PM
FAF
Rent this space
Its not trig its geom or even kinematic, if you put a deadlink in place of the spring you will see a higher reading but still some losses depending on the angle of the swingarm and how stiff it is.
FAF is offline
post #9 of 11 Old 08-02-2007, 10:45 PM
inappropriate
Images: 67
thats a good idea
post #10 of 11 Old 08-02-2007, 10:46 PM Thread Starter
Speed Freak
garth285's Avatar
on a good note my rev extend is defintly working great, the guy was liek i was gunna hold it longer but didnt know when the limiter would hit....I forget what im geared to now but i think mid 170's
garth285 is offline
97 zx-9 needs extended Swingarm Jeckylll ZX-9R Discussion 2 06-27-2007 07:37 PM
Extended Swingarm Install pacdadee187 Performance and Tech 3 04-01-2007 09:09 AM
Extended Swingarm Install pacdadee187 The ZX-10R 3 03-31-2007 05:13 PM
06' extension or extended swingarm? alteredZX-10 Performance and Tech 9 04-06-2006 08:57 PM
extended swingarm lzbrown The ZX-10R 3 05-24-2004 08:58 AM
