Anyone found a way to better oil the gen 4 clutch - Kawasaki ZX-10R.net
 1Likes
post #1 of 16 Old 06-17-2018, 03:10 PM Thread Starter
97grnrs's Avatar
The gen 4 shifts smooth when cold but after it gets hot downshifts get sticky. Sometimes hard to push the lever down without extra force, I've changed clutch to rule out warping plates etc. Seems better when i re soak fibers in oil but after few days it goes back to same notchy downshift once hot. I'm thinking theres just not enough oil circulation on the gen 4 clutch. Anyone find a solution to this
04 1000rr, 05 zx10 rocket...check out some of my work in my albums link.. https://www.zx-10r.net/forum/album.php?albumid=3114
97grnrs is offline
post #2 of 16 Old 06-17-2018, 11:47 PM
michael4012's Avatar
I'm not sure if heard that issue before, but if you have fitted a new pack correctly then what else could it be.
michael4012 is offline
post #3 of 16 Old 06-18-2018, 05:14 AM Thread Starter
97grnrs's Avatar
It seems the position of the gen 4 clutch being so high causes it to not get as much oil on the plates as previous generation.
97grnrs is offline
post #4 of 16 Old 06-18-2018, 08:28 AM
zx racer's Avatar
Some runing a oil line from oil pan to the cluch cover so clutch gets plenty oil might be worth looking into.
Sent from my SCH-I545 using Tapatalk
05 ZX-10R SWB.
zx racer is offline
post #5 of 16 Old 06-18-2018, 12:01 PM
If oiling the clutch was a real issue, it would happen to everyone. Lucky for us, it's not an issue at all with gen4 and 5 (and likely older gens too). I ran my gen4 for 10k miles on the track and never had this problem. The problem is probably with the transmission. I would say a bent shift fork. Luckily, Kawi was kind enough to make cassette-style gearboxes for our bikes so it's pretty easy and quick to remove it and replacing a shift fork takes 30 seconds. Just check the service manual on the step-by-step and don't rush it.
JayBoCC2 likes this.
Lanister is offline
post #6 of 16 Old 06-18-2018, 01:36 PM Thread Starter
97grnrs's Avatar
Def don't think shift fork issues or it would not get better or worse with temp, from searching it seems to be a number of the gen 4 have had the issue and re oiling the plates is just a temp fix to a poor design. Possibly some suffer from it worse than others,
97grnrs is offline
post #7 of 16 Old 06-18-2018, 01:46 PM Thread Starter
97grnrs's Avatar
And it's also not gear dependant so no way every shift fork is bad. Clutchless downshift doesn't have the issue but I don't like doing that
97grnrs is offline
post #8 of 16 Old 06-18-2018, 02:42 PM
badassjake's Avatar
there is a trick of notching the clutch pull shaft(1/8th ") .....this lets more oil flow out to the basket....more oiling holes needed on the clutch basket to get the oil to spots to effectively cool the plates.
badassjake is offline
post #9 of 16 Old 06-18-2018, 03:23 PM
Maybe new clutch springs? They do weaken over time and have to be replaced periodically.
Lanister is offline
post #10 of 16 Old 06-18-2018, 03:28 PM Thread Starter
97grnrs's Avatar
Ya I just replaced the whole clutch with a gen one setup. New heavier springs also. Any info on notched pull rod?
97grnrs is offline
Gen 4: Surprise!!! Look what I found out what works in my clutch! PatrickG Strip 40 03-01-2015 06:27 PM
Gen 1 clutch cover oil seepage Boots The ZX-10R 5 04-18-2011 02:35 AM
found brass flakes in my oil copperelite Performance and Tech 15 01-20-2011 06:22 AM
Removed Secondaries...found some oil???? walkthisway21 Performance and Tech 8 04-04-2008 04:13 PM
Found a new tool that is mandatory for oil changes JodyH Performance and Tech 9 12-10-2005 05:56 PM
