Any Idea's what the Pipe is for? - Kawasaki ZX-10R.net
post #1 of 13 Old 01-13-2010, 03:37 AM Thread Starter
Bounce's Avatar
Check the Pipe going into the Oil Filler spot:
Name:	10012010092 [1024x768].jpg
Bounce is offline
post #2 of 13 Old 01-13-2010, 03:38 AM Thread Starter
Bounce's Avatar
I was told that it is a performance modification which reduces the air pressure in the motor, for the pistons to move easier.
Now I dont know how true it is???
Bounce is offline
post #3 of 13 Old 01-13-2010, 04:18 AM
Dont mess wit White Ninja
abzx10r's Avatar
i want to know the exhaust on that bike!!
abzx10r is offline
post #4 of 13 Old 01-13-2010, 06:36 AM Thread Starter
Bounce's Avatar
Arata:
Name:	08_zx10 [800x600].jpg
Bounce is offline
post #5 of 13 Old 01-13-2010, 08:16 AM
nickalltogether's Avatar
Why did Arata have to stop making exhausts :(
Some people run a line like that to help oil their clutches, but it is mostly worthless for that purpose.
2012 Kawasaki ZX-6R-Black
Clear Alternatives Tail Light
2005 Honda F4i-Red
Commuter stuff
2003 Yamaha Zuma-Fairy Silver
TPT 70cc Kit, Leo Vince ZX Exhaust, Malossi Delta Clutch, Scott's Damper Sticker
nickalltogether is offline
post #6 of 13 Old 01-13-2010, 08:22 AM
zx10Duran's Avatar
wouldnt a more simple breather be better?
lotta newbies, where did all the regulars go?
zx10Duran is offline
post #7 of 13 Old 01-13-2010, 08:44 AM
beenthere's Avatar
Usually that type of set-up is connected up top to the anti polution air injection at the exhaust port. In its stock configuration it injects filtered air from the air box to the exhaust ports to help fire off any unburnt mixture thus reducing unburnt hydrcarbons on trailing throttle-making your kwacker more eco friendly. You can (as in the photo) run a breather line from any spot on the crankcase plumb it to the exhaust port anti pollution system and the high velocity in the exh ports creates negative pressure which helps to "unload" some of the pumping loses in the crankcase. And yes theoretically the pistons should rise and fall easier, making your motor happier to produce more hp. If your motor isn't worn out (ie, good ring seal) and of stock cc's the original breather system should be adequate. Big cc motors or motors with cylinder leak down will be the ones that benefit mostly from this type of secondary breather.
beenthere is offline
post #8 of 13 Old 01-13-2010, 09:18 AM
Supercharged Mod
But, why not route it to the breather outlet on top of the crankcase the way it's usually done? That connection point has a separator to keep the liquid oil in the crankcase.
Going straight to the filler cap seems like an invitation for oil to splash out into the suction hose and lead to very high oil consumption. Maybe the length of the hose acts sorta like an oil separator. At a minimum, going this route just adds more complication to doing an oil change.
GoFaster is offline
post #9 of 13 Old 01-13-2010, 09:29 AM
beenthere's Avatar
The secondary breather is only effective when the engine has enough rpm to produce vacumm or negative pressure in the exhaust ports. That would be why this type of set-up is more common to a "race" bike than a street bike. Since the street bike must have crank ventilation at or near idle the stock vent routes to the air box to utilize intake vaccumm (and combustion) to rid the crankcase of fumes and pressure. But the performance minded street guy can benefit from this secondary breather when used in conjunction with but seperately from the factories primary breather. Back in the day of Z1 drag bikes (circa '73 to about '78) we would connect a hose from the original crank breather nipple to a bung 8 inches down stream of the collector to use the wot exhaust velocities negative pressure to evacuate the crankcase and eliviate its potential pumping losses. This was crude but effective, we didn't care about the bikes street function 'cause it never saw the street or part throttle usage. Todays bikes being much more sofisticated require a bit more sofisticated solutions. (excuss my spelling problems)
post #10 of 13 Old 01-13-2010, 10:13 AM
JVT
maybe theres a hidden turbo? J/k
JVT is offline
2010 zx-10r any thoughtz or idea's? ZiG 9th The ZX-10R 140 10-09-2009 03:10 AM
Yoshi TRC slip-on pipe... link pipe? jryanfallon The ZX-10R 1 05-21-2009 10:13 PM
Paint Scheme Idea's RickRoush03 General Motorcycle Discussions 4 02-24-2008 10:20 AM
misfiring under load!!! Any idea's speedtechnz Performance and Tech 17 08-01-2007 10:01 AM
my new pipe kiwifruit Pictures and Videos 35 11-15-2006 01:33 PM
