Gen 2: 2006-2007 Another Electrical Question - Kawasaki ZX-10R.net
post #1 of 3 Old 04-29-2013, 12:21 PM Thread Starter
rkd
Where is the negative battery cable connection to the bike?
The wiring diagram shows it going directly to the bike as ground. Its hard to trace and I forgot to do it Sat. How to you access it?
Looking to find and clean. Maybe an old Ford fix will work?
Also how do you access the pos connection to the starter motor?
Thanks.
rkd is offline
post #2 of 3 Old 04-29-2013, 12:59 PM
SkyDork's Avatar
There is a ground lug in the frame cross member under the tank. It's pretty obvious once you remove the tank. It's a bolt screwed into the frame with several wires attached to it.
The starter motor connection will be evident while the tank is off as well. It's a cable terminal lug with a rubber dust cap over it. Just slide the cap back and unscrew the terminal to remove the wire.
You should download the service manual as all of this is explained in there with pics to help you out.
#WordCrimes
SkyDork is offline
post #3 of 3 Old 04-30-2013, 08:06 AM Thread Starter
rkd
Thanks. I found, cleaned and tightened the lug with the two wires under the tank. I just did not trace it to the actual neg cable from the battery. Left the gasline connected to the tank, just had it loose. Trying not to take the whole thing apart just yet.
rkd is offline
Gen 2: Question about Electrical sromero The ZX-10R 4 03-09-2013 11:56 PM
Electrical question? RickRoush03 The ZX-10R 20 03-25-2007 07:18 PM
Household electrical question. focalf5 The Out House 14 02-20-2007 04:46 PM
Quick electrical question.. ninja9rc The ZX-10R 0 07-14-2006 07:48 AM
Electrical system question. hayabusa57 The ZX-10R 1 06-05-2004 02:11 AM
