Another Dyno Question - Kawasaki ZX-10R.net
post #1 of 5 Old 04-29-2008, 05:04 PM Thread Starter
Ronnie@South Seas's Avatar
I have an 06, and I got it dynoed stock then I did another when I got the full system installed. The first time I was on the dyno I did not notice but I did the second time, they have fans but do not turn them on. So, I asked why weren't the fans on and he said we only use them when we custom tune. Is that the case with all dyno's or does that shop just want it to seem like your numbers are that much better than they really are.
[email protected] Seas is offline
post #2 of 5 Old 04-29-2008, 05:48 PM
Big Daddy's Avatar
Images: 38
the fans should always be used, that said a simple single pull doesn't generate near the amount of heat compared to numerous pulls & constant running while tuning so perhaps their reasoning i dunno.
Big Daddy is offline
post #3 of 5 Old 04-30-2008, 01:13 AM Thread Starter
That makes since.
post #4 of 5 Old 04-30-2008, 08:43 AM
OneSLOW10's Avatar
Send a message via AIM to OneSLOW10
Wow! I would've gotten pissy. There a tuner station???? I'd leave lots of bad rep for them just based off of that. They act like your bike isn't worth the .02 it takes to turn the fans on just b/c your not spending $2-300 for a custom map. zzizzy my friend
2005 PMR. Full Ti Evo 2, BMC Race, V-Stacks, PC3, IG Module, DJ QS (not installed), 1/5th throw (not installed), -1 +2 with Gold RK Chain, Speedo Healer V4, Removed 2ndaries, Red GiPro, Pilot Powers, Dual H.I.D.s, Brocks brackets and strap, Rear 2" Muzzy Drop, Vortex Rearsets, Scotts Damper, 2 HyperPro Dampers, Puig DB, ASV Levers, Titax Levers, Pazzo Levers, Kill switch (made to look like it's mounted), CA front/rear lights and a owner who adores her...
OneSLOW10 is offline
post #5 of 5 Old 04-30-2008, 03:56 PM Thread Starter
Yeah they are a authorized PC tuning center.
dyno question rojapar Performance and Tech 10 07-29-2007 06:04 PM
dyno question, which gear? leemille Performance and Tech 13 03-09-2007 07:33 AM
Awesome first rally and dyno run share dyno numbers No-Mo The ZX-10R 36 05-19-2006 05:53 PM
Dyno question oof440 The ZX-10R 0 08-30-2005 04:21 PM
Dyno Question???????????????? SP8 The ZX-10R 27 09-10-2004 04:53 PM
