Another Cam Degreeing Question - Kawasaki ZX-10R.net
post #1 of 9 Old 01-15-2015, 04:58 AM Thread Starter
michael4012's Avatar
I'm wondering what you guys over in the USA prefer to use for checking valve to piston clearance I'm using a modelling clay although iv used solder wire for checking the squish I'm told that even that can expand back once the pressure is off.
michael4012 is offline
post #2 of 9 Old 01-15-2015, 02:51 PM Thread Starter
Bump
post #3 of 9 Old 01-16-2015, 10:56 AM Thread Starter
Bump please somebody
post #4 of 9 Old 01-16-2015, 12:35 PM
kman0066's Avatar
I put a dial indicator on the valve and pushed the valve down until it touches the piston. Dial indicator shows you the distance traveled to the piston.
WERA Expert #43
2012 WERA National Challenge Series Open Superstock Novice Champion
http://maps.wera.com/racers/racerpro...30532136163864
COMET RACING LEATHERS
2011 ZX-10R Race bike (Vortex, Silkolene, Leatt, Yoshimura, BRIDGESTONE)
2013 ZX-6R 636 Race bike
2008 Ducati Hypermotard 1100s
kman0066 is offline
post #5 of 9 Old 01-16-2015, 09:50 PM
badassjake's Avatar
yup! ^^^
badassjake is online now
post #6 of 9 Old 01-16-2015, 09:56 PM
Same here... All that clay/ soldier squishing BS is just that BS. When you stop to consider the average human hair is .002" and the difference in a piston that hits and one that don't hit can be a matter of 3 or 4 hairs how much guess do you think there's room for?
Gunner is offline
post #7 of 9 Old 01-16-2015, 11:36 PM
I use solder to check squish as that is different from Ptv. Squish is on the shoulders of the pistons. I check Ptv with dial indicator.
ccmhunt is offline
post #8 of 9 Old 01-17-2015, 12:13 AM
theatiss's Avatar
I use same method
u could check race kit manual for sure
Gen3 : Arata full exhaust , KN air filter , 520 DID Renthal , oem Ecu converted to Race Kawasaki Ecu , milled ported head , Kent camshafts , lowered , Pk shifter , 14k rev limiter . Ecu tuned by TRE ( mr Balogiannis)
http://www.youtube.com/watch?v=eLsF4A1k_ew
theatiss is offline
post #9 of 9 Old 01-17-2015, 12:37 AM Thread Starter
brilliant guys thanks for your advice
Cam degreeing help needed! zx10racer Performance and Tech 13 03-05-2012 09:57 PM
Cam Degreeing 06ninjaturtle The ZX-10R 2 01-18-2011 09:57 PM
Cam Degreeing setup supperdaddy Performance and Tech 16 08-27-2007 05:15 PM
cam degreeing? Floyd Performance and Tech 2 04-12-2005 11:26 AM
Cam Degreeing Question !!! Bobster Performance and Tech 7 04-05-2005 03:15 PM
