Gen 1: 2004-2005 Another Caliper question! - Kawasaki ZX-10R.net
post #1 of 4 Old 04-28-2011, 04:08 AM Thread Starter
Crownan's Avatar
Before anyone says it, I have searched and looked through countless threads on the subject but cant find the answer to this specific question!
Are the pads on the 04/05 ZX10R front Tokicos the same pads on on the 08/09 ZX6R Nissins?
Cheers.
Crownan is offline
post #2 of 4 Old 04-28-2011, 06:09 AM
All show and all go 10r
JLG0987's Avatar
Don't know if you look up part numbers you should get your answer quick.
JLG0987 is offline
post #3 of 4 Old 04-28-2011, 06:10 AM
Flipr's Avatar
Checked the part #'s at a couple of sites and looks like they are a different pad.
Area P slip-on & link pipe,De-catted Headers,PCV & Autotune,Ivans block off plates,K & N filter,X-Tre,Driven Superlite sprockets,+2 rear,stock front,520 conversion,V4 Speedohealer,Servo motor eliminator,Re-valved Ohlins damper,Spiegler front brake lines,Zero Gravity SR dark smoke screen,Stompgrip tank pads,ZX-6 rear cowl,and more to come.
Speed dosen't kill,it's the sudden stop!!!
Flipr is offline
post #4 of 4 Old 04-28-2011, 06:29 AM Thread Starter
Crownan's Avatar
Ok thanks :)
Crownan is offline
CBR Caliper Question CrescentisRising The ZX-10R 8 07-01-2010 03:14 PM
a question for those that have done the caliper swap ash01s2001 Performance and Tech 7 09-12-2009 12:53 PM
caliper question zero4o3 Performance and Tech 6 03-15-2009 08:11 PM
caliper question adrenaline The ZX-10R 16 01-14-2009 07:29 PM
Another caliper question JD81 Performance and Tech 5 12-03-2007 04:14 PM
