another 16T sprocket thread - Kawasaki ZX-10R.net
post #1 of 9 Old 07-24-2005, 06:09 AM Thread Starter
K10
K10's Avatar
ok, I searched and searched, but I can't seem to find what I'm looking for. I want to switch to the 16T sprocket, but I remember someone saying it was more noisey than the stock. I think someone posted that a stock 16T sprocket from another bike included the rubber noise damper (not sure whatelse to call it) and would work on the 10? Anyone remember or know what it was?
One more thing..exactly how many MPH will the speedo off (I'll get the healer later)?
thanks
K10 is offline
post #2 of 9 Old 07-24-2005, 06:44 AM
Images: 7
Ground Zero is offline
post #3 of 9 Old 07-24-2005, 06:58 AM Thread Starter
K10
K10's Avatar
that's it man! thanks
Hey, What year Z1000?
K10 is offline
post #4 of 9 Old 07-24-2005, 08:37 AM
Images: 7
It's a late model Z1000, don't know what year. I think the Kawi part number is in the thread.
post #5 of 9 Old 07-24-2005, 11:23 AM
When changing to a 16T front sprocket, do you need to change the chain out as well? I know the lenght will still work, maybe increase the wheel base slightly....but usually its said to change both sprockets and chain out at the same time becuase they wear together.....
TTLex is offline
post #6 of 9 Old 07-24-2005, 03:29 PM
10 speed's Avatar
just shorten it or pull the wheel in.
My question= Does this sprocket get rid of the bogg?
10 speed is offline
post #7 of 9 Old 07-24-2005, 04:21 PM
Post Whore
El Diablo's Avatar
Probably depends on how many miles you have when you swap sprockets. I swapped to a 16t within a few hundred miles so I didn't worry about the chain and rear sprocket. If you've got a couple thousand miles or more it might be wise to change it all together. It has probably established a certain wear pattern by then and will probably wear faster if you only change one sprocket.
I swapped early in mileage on both my busa and the 10 and didn't see any noticeable wear when I got rid of either one...
"Bottom line, when I'm on that bike, it's just me and God...And He better be holding on."- Stillie on SSB
Si vis pacem, para bellum...
El Diablo
El Diablo is offline
post #8 of 9 Old 07-24-2005, 04:24 PM
Post Whore
El Diablo's Avatar
What bog? My 10 never bogged. It's down on torque at lower RPM's but no bog anywhere in the RPM range... If you're asking whether or not the 16t improves low end grunt, yes, it helps. It doesn't make it a torque monster from stoplights during normal take offs but it does multiply torque more than the stock gearing.
El Diablo
post #9 of 9 Old 07-25-2005, 10:06 PM
<<My question= Does this sprocket get rid of the bogg?>>
The bike's ECU is programmed to retard the timing for a fraction of a second upon closing/reopening of the throttle under low RPM conditions, hence the bog. They ALL will do it if not modified, unless you wring it out each time you shift it! I'm not sure what the RPM threshold is, but your local Kaw dealer service man should know, if they'll admit this is the case. It's apparently done as some sort of a liability issue to Kawasaki, but I think it's b.s.! There's no excuse for a bike of this caliber to be missing or bogging anywhere! You can find people that sell components to stop this condition-some sort of a signal-blocker. Or you can just bang every gear instead and not worry about it! Hold on is all I can say if so!!
fatrock is offline
Ok, my front sprocket was easy... -install with pics El Diablo Performance and Tech 122 04-02-2015 03:51 PM
Ok, my front sprocket was easy... El Diablo How To... 1 02-07-2005 11:10 PM
16t sprocket fbdr24 The ZX-10R 2 11-07-2004 12:19 AM
16T Sprocket - How hard is it to install this? RichTJ99 Performance and Tech 24 06-30-2004 03:23 AM
