Gen 4: 2011-2015 Annitori QS with Power Commander 5? - Kawasaki ZX-10R.net
post #1 of 10 Old 01-08-2015, 09:26 PM Thread Starter
DJNMS3's Avatar
My buddy just bought a Gen.4 ZX-10R. It has the ECU flashed by Guhl, no fuel management, and an Annitori Quick Shifter. Just curious if it is possible to run the Annitori Quick Shifter with the Power Commander 5? If so, is there any other expansion module or mods you would need to run those two together?
Any help is greatly appreciated!
Thanks!
DJNMS3 is offline
post #2 of 10 Old 01-08-2015, 10:29 PM
MiaZx10r's Avatar
Yeah you can run both. The quick shifter harness goes in-line with the coils cutting ignition. The power commander goes in-line with the fuel injectors so you shouldn't have any issues running both of them. They are each their own system. No need for anything else to run them.
MiaZx10r is offline
post #3 of 10 Old 01-09-2015, 03:17 PM Thread Starter
DJNMS3's Avatar
Thank you, sir!
DJNMS3 is offline
post #4 of 10 Old 01-10-2015, 07:14 AM
Somefun's Avatar
I have very new Annitori Quick Shifter for sale. It was used two months if your interested......
Spegler SS lines with EBC HH pads front n rear along with Brembo M4 calipers, EBC front and rear rotors, Brembo Radial MC & Brake Levers, Sato rear sets, BST carbon fiber wheels, Pirelli Diablo Super Corsa SP, Ohlins TTX EC Rear Shock, revalued steering damper, leatec gas cap, Don Guhl Reflash, Akropovic & linked pipe. HM quick shifter,green silicon hoses, Shoria battery and shimmed the rear 5mm and lastly (for now) an EBC Kevlar race clutch & HD springs, Vortex case covers.
Somefun is offline
post #5 of 10 Old 01-11-2015, 12:37 PM Thread Starter
DJNMS3's Avatar
My buddy already has the quick shifter. He's just looking for a Power Commander 5 now.
DJNMS3 is offline
post #6 of 10 Old 01-11-2015, 12:38 PM
ZX-10R enthusiast
dudewhrsmybike's Avatar
This.
Strictly for my Ninjas
https://www.instagram.com/mistr.123/
Current Ride: 2016 ZX-10R ABS (under construction)
Former Ride: 2011 ZX-10R ABS
17/41, Woolich Racing Tuned ECU and QS, Rifleman's 1/5th throttle insert, CL XBK5 pads, Yosh case sliders, Mivv Carbon w/ Ti Akra link
dudewhrsmybike is offline
post #7 of 10 Old 01-17-2015, 09:50 PM
Somefun you still have QS?
mzottmann is offline
post #8 of 10 Old 01-19-2015, 10:01 AM
MiaZx10r's Avatar
I'm buying it just waiting for him to take it off
MiaZx10r is offline
post #9 of 10 Old 02-15-2015, 06:38 AM
I had nothing but problems running the annatori qs with the power commander v and ignition module.
All that piggy backing was causing weird things to happen. I tried everything but eventually
Removed the quickshifter and replaced it with a dynojet shifter which stopped all these problems occuring.
I know in theory they should work together, dynojet said so, annatori said so but my experience the 2009 zx10 I got was not happy with all that piggybacking going on.
Ardent is offline
post #10 of 10 Old 02-19-2015, 10:59 PM
A Squids Life's Avatar
I know its not a problem for you now, but did you check to make sure the coil positive connected to the positive on the shifter loom? Mine had one around the wrong way which caused issues.
A Squids Life is offline
Gen 3: Power commander? jimmy012308 The ZX-10R 4 05-30-2014 05:58 PM
Power Commander 04-05 t3mpo83 Vendors deals 8 09-28-2009 08:44 AM
08 Power Commander ZX10Rip Performance and Tech 9 04-09-2008 02:51 AM
power commander? Wind Draft Vendors deals 2 02-27-2007 11:59 AM
