Gen 1: 2004-2005 Alternator 2004 vs 2005 - Kawasaki ZX-10R.net
post #1 of 2 Old 05-12-2011, 05:39 PM Thread Starter
Does not drive into smoke
El Zilcho's Avatar
It's quite possible that my alternator is broken. I've been investigating some issues with my bike and so far alternator seems like a culprit. I haven't had time to take it out yet, but I wanted to get some info about something else (but a bit related). I know that the 2004 alternators have some issues that can lead to a premature failure. Apparently that problem was solved in 2005.
If I have a 2004 alternator, would it be possible to "upgrade" it to a 2005 (or at least to eliminate the problem) by using parts from 2005? Some parts in the diagrams look obviously different, but are there parts that look the same, but aren't really the same?
What is the minimum set of parts that I would need (apart from anything that may currently be broken)?
Here are the diagrams:
2004
2005:
El Zilcho is offline
post #2 of 2 Old 05-14-2011, 02:27 PM
lenshead's Avatar
I swapped mine out a couple years ago. If I recall, the individual parts were really expensive, I just used a whole alternator off of Ebay for much less $$$
If you go used, be sure you get a 2005, as some will list either one as a 1st gen part, failing to distinguish '04 from '05.
Thou Shalt Respect Thy 10, And Revel In It's Power, For It Is Good, And Plentiful.
lenshead is offline
2004 - 2005 parts OneSLOW10 Parts, Gear and Accessories 24 05-12-2008 09:35 PM
key set 2004-2005 samizx7 Parts, Gear and Accessories 3 12-12-2007 04:46 PM
2004 2005 ZX-10r griffenzx10 Parts, Gear and Accessories 18 09-21-2007 05:35 PM
2004 vs 2005 zx-10r Sn95dude The ZX-10R 10 06-26-2006 08:57 PM
R1 2004 vs 2005 10r GREEN 10R Race and Stunt 14 06-26-2005 01:54 PM
