Akro Evo 2 Install Question - Kawasaki ZX-10R.net
post #1 of 10 Old 10-04-2004, 11:09 PM Thread Starter
Question Akro Evo 2 Install Question
Installed the full system today. Followed the instructions to the letter. Had a slight exhaust leak initially, worked the headers in alittle better & problem gone. 2nd problem. The collector the leads into the muffler is rubbing on the center pivot bolt on the linkage arm for the rear shock. I have tried to work it away from this w/ no luck. Has anyone ran into this problem? If so, any advice would be appeciated!
zeeX10R is offline
post #2 of 10 Old 10-05-2004, 02:37 AM
BANNED
My Devil Racing Shotguns never leak or rub anything . Never had any problems other than people drooling over them .
tberd is offline
post #3 of 10 Old 10-05-2004, 03:25 AM
Smile
Did mine Saturday, same problems. I pulled the pipe out in the shock area today and it clicked and stayed out. If it was not going to stay out I was going to install a band clamp in that area to keep the pipe from rubbing.
Or you could sell your crap Akra and buy that wonderful Devil system :>)
BIKEMIKE is offline
post #4 of 10 Old 10-05-2004, 10:35 AM
Andy's Avatar
Images: 25
moved to tech
Andy is offline
post #5 of 10 Old 10-05-2004, 11:45 AM
you might have the exhaust clamp on backwards, turn that badboy around and it should move it away from the bike more. i did this at first and then flipped it around and then it cleared much better. the way it looks like it should go is the wrong way imo.
seebr900 is offline
post #6 of 10 Old 10-06-2004, 01:43 AM Thread Starter
Yes, I did. I ended up just about completely reinstalling the entire system today. Same problem. I used the bushings from the mid pipe of the stock exhaust to space the mount off the CF bracket that holds the Akra cannister. This looks to have given me about a 1/2 inch of space which should do the trick. Don't look bad either. Thanks
zeeX10R is offline
post #7 of 10 Old 10-06-2004, 09:40 AM
Any pics?
Rattler is offline
post #8 of 10 Old 10-07-2004, 11:18 PM Thread Starter
I will take some & post as soon as I get a minute to click.
zeeX10R is offline
post #9 of 10 Old 10-08-2004, 03:16 AM
Krazy1's Avatar
I had a problem with all of this before. Ends up that the carbon fiber bracket they sent with my system was formed wrong pulling the system up and over. I just got the bracket this week after two months of going around with lockhart. I realy love this system but dam for the price it should fit better the first time around.
Krazy1 is offline
post #10 of 10 Old 10-09-2004, 11:39 AM
I used my stock hanger and had no problems, I still wanted to keep my rear pegs.
gtsmpuc is offline
Full akro dyno # and some piece of mind Krazy1 The ZX-10R 26 07-26-2004 06:00 PM
Full Arata VS. Akro Slip-On JLove The ZX-10R 40 07-05-2004 12:12 AM
Tunning th Akro EVO 2 system with PCIIIusb. Daveszx10 The ZX-10R 11 05-20-2004 02:10 AM
Akro dyno runs Krazy1 The ZX-10R 6 05-12-2004 04:24 PM
