Akra Slip-on Exhaust Problem - Kawasaki ZX-10R.net
post #1 of 14 Old 01-27-2008, 04:46 PM Thread Starter
Tweek218's Avatar
I am a beginner so this might sound dumb, but I am having problems installing the slip on exhaust for my '05. I've searched, but haven't found anything.
Everything is fine except for one thing...the backet Akra sends with the kit that mounts at the header to hook the spring onto the mid pipe. I removed the screw the instructions said to remove (Red Arrow), but when you try to install the bracket behind the rubber washer, there's a part of the header that gets in the way (Small yellow arrow). It's a welded triangle support. When I put the little bracket in the place the instructions tell me to, it won't let me tighten down the screw correctly. It's hard to explain, but I know someone with the exhaust might know what I am talking about.
Again I am new to bikes, so this could be a stupid post. That bracket might not even be for my year Zx10, but the instructions say for 04-05.
I can't find my camera cord to load pictures, this is the best I can do using someone else's...as soon as I can get better pictures I will.
Also, if I can't figure this out, would it be safe to run the exhaust without the spring attaching the midpipe to the header. Is the clamp enough? Right now it looks like this...clamped down obviously but not using the spring.
Thank you.
Tweek218 is offline
post #2 of 14 Old 01-27-2008, 05:15 PM
Big Daddy's Avatar
Images: 38
yea a couple members mentioned this awhile back but yes the dogbone like brkt is for your bike so no worries. I know the exact issue your having and if my feeble memory serves me i recall bending it outward (away from pipe) in order to get by the support and it worked fine but don't quote me on this.
you could go without it as the clamp and the rear passenger peg brkt is enough to secure it.
Big Daddy is offline
post #3 of 14 Old 01-27-2008, 05:33 PM
Bradlee_T's Avatar
Images: 9
I have had mine off for a while. I left it off when I installed it and it is just fine without it.
Bradlee_T is offline
post #4 of 14 Old 01-27-2008, 05:58 PM Thread Starter
Tweek218's Avatar
Thanks guys. Yeah my friend said why don't I just bend the bracket. It's hard to explain without looking at it, but even bending it I still can't see how it would work. When I get it positioned the way the directions say to, the bracket prys the header away from the part of the frame it attaches to. I can't get everything to fit against each other flush. Big daddy, do you still have the bike? If you get a chance can you take a picture of how you did it. Or if anyone else can take a picture of what they did, that would help too. Thanks again.
Otherwise I'll just use the clamp. The stock muffler was only held on by a clamp, so like you said I'm sure that will do.
Tweek218 is offline
post #5 of 14 Old 01-27-2008, 07:08 PM
Big Daddy's Avatar
Images: 38
i no longer have my 04(which apparently is diff) so i'm of no help here.
Is it possible to shim it outward to gain the necessary space to bypass it??
post #6 of 14 Old 01-27-2008, 08:57 PM Thread Starter
Tweek218's Avatar
Here's a better picture showing what I mean...
They say to install the bracket behind the round washer (Red Arrow), but the part with the yellow arrow is blocking it. I don't think bending it will work, because then the header and frame won't line up flush to be able to be tightened down by the bolt. Because of the high tension of the spring, shouldn't the bracket be straight too?...eh I don't know. If anyone can give me some info that would be great, if not I just won't use that spring. Thanks again.
ID:	57381   Click image for larger version
Tweek218 is offline
post #7 of 14 Old 01-27-2008, 09:14 PM
b_silva2000's Avatar
Send a message via AIM to b_silva2000
i have ur solution...eating. post up pics in 10 mins
b_silva2000 is offline
post #8 of 14 Old 01-27-2008, 09:28 PM
here we go...this is what i did with mine. No bending. This was the only combination that worked
post #9 of 14 Old 01-27-2008, 10:13 PM
Andy's Avatar
Images: 25
I actually ran mine without the little t bone for a while for some reason. Like BD said it's really not necassary, the hanger and the clamp are enough to hold it on. If you can get it to work fine, but don't strees if you can't.
Andy is offline
post #10 of 14 Old 01-27-2008, 10:20 PM
Accountant in training.
Deer Elk's Avatar
I think I just flipped the bracket thing around. Seems to work fine for me. Or maybe I did the same as b_silva2000.... I'll check tomorrow... But by then you'll have probably come up with your own solution.
Good luck and enjoy the pipe. It'll sound a bit better after a few miles loosen it up.
Chris
Deer Elk is offline
Akra Hex slip on Alien10 Vendor Deals 2 05-17-2007 12:16 PM
Akra Slip ons. Speedyj Vendor Deals 4 09-20-2006 10:13 AM
Akra c/f Slip/on No-Mo Parts, Gear and Accessories 10 07-29-2006 12:12 AM
Akra slip on zx10uk The ZX-10R 2 08-25-2005 11:23 AM
PC map for akra slip-on silvrsled The ZX-10R 3 07-19-2004 01:08 PM
