AIS mod went bad - Kawasaki ZX-10R.net
post #1 of 23 Old 01-18-2010, 08:08 AM Thread Starter
AIS mod went bad
Tried to do AIS mod the way everyone posted and now my bike wont start. i have 2007 zx10r with full muzzy gp exhaust custom map and bmc air filter. please help.
snicky10r is offline
post #2 of 23 Old 01-18-2010, 08:38 AM
nickalltogether's Avatar
Sorry I can't help you with the problem, but welcome to the site. Where are you from in NC?
2012 Kawasaki ZX-6R-Black
Clear Alternatives Tail Light
2005 Honda F4i-Red
Commuter stuff
2003 Yamaha Zuma-Fairy Silver
TPT 70cc Kit, Leo Vince ZX Exhaust, Malossi Delta Clutch, Scott's Damper Sticker
nickalltogether is offline
post #3 of 23 Old 01-18-2010, 09:09 AM
beenthere's Avatar
Geez, Sure would like to help but its kinda hard to know what you did or didn't do. Did you check for anything electrical left unplugged, any pinched hoses, any crossed hoses? I made this mistake in the past but not so much anymore--Does it have gasoline? Good luck, when you find it, you'll say damn howed I do that? Bye the way, if when you are trying to start the motor it seems to lock up on compression, you may have a cylinder or cylinders hydro locking with gasoline. Its more common with gravity fed carb bikes than fuel pump injection, however since I don't know what kind of problems you are experiencing, should you have a hydro locking issues, don't keep trying to turn it over. Hope some of this info helps.
beenthere is offline
post #4 of 23 Old 01-18-2010, 09:48 AM
TENN10's Avatar
Images: 145
Did you have your tank off? Fuel line pinched maybe?
Gonna need more info. to help.
TENN10 is offline
post #5 of 23 Old 01-18-2010, 09:55 AM Thread Starter
thanks for trying. i live in goldsboro.
post #6 of 23 Old 01-18-2010, 11:22 AM
fireman69's Avatar
Check to make sure your fuel pump is plugged in. Make sure your plug coil leads are pushed in all the way also.
Does the bike turn over? do you hear a whine from inside the fuel tank when you cycle the key? does it try to fire but not catch? Need more info please
fireman69 is offline
post #7 of 23 Old 01-18-2010, 12:09 PM
Quick10's Avatar
I'm sorry Just kidding I lived there for about 7 years. Good luck finding the problem and welcome to the site
Originally Posted by NinjeR View Post
I'm glad I'm a stripper, the money keeps coming in! lol
Quick10 is offline
post #8 of 23 Old 01-18-2010, 04:18 PM Thread Starter
bike turns over fine, but doesn't start. checked all fuel lines and wires. fuel pump does its normal thing.
post #9 of 23 Old 01-18-2010, 05:00 PM Thread Starter
One thing I failed to mention was the first time I got the bike together I forgot to hook up the fuel pump wires. It started but died and now it wont do anything but crank with the wires connected. Do you think it could be that the plugs are now fouled out.
post #10 of 23 Old 01-18-2010, 05:08 PM
The plugs would only foul if you were getting fuel but no spark. Check all the obvious things: make sure it's in neutral, kickstand up, clutch pulled in, key and kill switch in the run position, tip over sensor not disconnected or oriented funny... Hope that helps.
2005 Honda F4i-Red
Commuter stuff
How To remove KLEEN / AIS for Cal / 50st bikes Big Daddy Performance and Tech 148 08-25-2014 08:31 AM
HOW TO: 3rd Gen AIS Removal / Block Off Plates install Lucky10R Performance and Tech 21 12-12-2009 03:00 AM
Brake mod gone bad Gang Green Performance and Tech 8 11-22-2007 10:10 PM
AIS block or clamp for tuning...how to? zx10rflus Performance and Tech 6 08-10-2005 11:02 PM
How To remove KLEEN / AIS for Cal / 50st bikes Big Daddy How To... 79 10-26-2004 02:21 PM
