air shifter on stock zx10 - Kawasaki ZX-10R.net
post #1 of 6 Old 11-25-2008, 08:14 PM Thread Starter
leZx10's Avatar
can i use it without having problems? or do i need to have a power commander in order to use it?
leZx10 is offline
post #2 of 6 Old 11-25-2008, 08:17 PM
Shorty's Performance
madnessracing's Avatar
If you're planning on using an air shifter you dont need the power commander.
madnessracing is offline
post #3 of 6 Old 11-26-2008, 09:43 AM
TMAC's Avatar
Images: 86
I don’t know a ton on the subject but it’s my understanding an air shifter forces a shift with air pressure and the power commander actually cuts spark and/or fuel to temporarily put the bike in a state of neutral while you manually shift the bike. I think the power commander option offers less wear and tear but the air shifter may be the faster route if you are drag racing and don’t want to shift your weight.
2007 ZX-10R - 156 RWHP/182 MPH
2009 KX450F
2006 636 (Sold)
99 ZX-6R (Sold)
94 Ninja 250 (Sold)
99 YZ-250 (Sold)
73 CL 450 (Sold)
http://www.youtube.com/watch?v=a6Jpc...eature=related
http://videos.streetfire.net/video/H...bud_408656.htm
TMAC is offline
post #4 of 6 Old 11-26-2008, 09:54 AM
goldfish's Avatar
The electric over air shifter that are currently available from company's like MRE/Pingel/APE and such don't work for modern bikes with stick type coils, like the zx-10r. You have to get an upgraded kill box if you are wanting to use the air shifter. Now the PC3 has whats called a quick shifter, but this doesn't shift the bike for you it just cuts ignition so you can shift the bike at full throttle with out the clutch, but its not the same as the air shifter, where you just hit a button and every thing is done for you. Some links below.
The third one down and below will work, because of the Adjustable Electronic Engine Kill Module.
http://www.pingelonline.com/super_el...hifter_kit.htm
I never gave it to anyone that didn't deserve it...
goldfish is offline
post #5 of 6 Old 11-27-2008, 09:33 PM
bugman53's Avatar
Actually they do work, all you haft to do is tie the 4 positive wires off the stick coils together and run the kill in series with the normally closed connection. Do it all the time and it work great. It kills the power to the coils and they canít spark, the computer grounds the coils to spark so there are no ill effects.
High Velocity Cycles 2005 Ti ZX10R
Greeensboro NC
bugman53 is offline
post #6 of 6 Old 11-28-2008, 06:55 PM
goldfish's Avatar
I stand corrected, if thats the case then rock on.......... :deathmeta
goldfish is offline
Dynojet Shifter zx10 08 REQUIRMENTS gregory_gr Performance and Tech 5 06-04-2008 02:39 PM
what should a stock 04 zx10 run 04kawzx-10 Strip 18 07-30-2007 08:34 PM
zx10 ITEMS ON EBAY. STOCK EXHAUST, STOCK SIGNAL, QUARTER TURN THROTTLE. ENDING 2/13 Eric_The_Jew Parts, Gear and Accessories 0 02-12-2007 12:35 PM
WTB ZX10 stock Parts! bellevuetlr Wanted: Buy or Trade 5 01-18-2006 04:23 PM
Electric Shifter or Air Shifter??? Stud_wit_style The Out House 8 10-19-2005 06:41 AM
