air pressure - Kawasaki ZX-10R.net
post #1 of 26 Old 02-13-2011, 04:27 PM Thread Starter
nfranke's Avatar
air pressure
do you set your tire pressure to what is on the sidewall
nfranke is offline
post #2 of 26 Old 02-13-2011, 04:38 PM
Blitzkrieg
YB Legal's Avatar
max? nope, its a good starting point. then you can adjust it for riding style and preference. also each tire works better at different psi. soem like higher for mileage, and not a lot of aggressive riding, while others want max grip and performance, which typically sacrafices mileage.
YB Legal is offline
post #3 of 26 Old 02-13-2011, 05:24 PM
Racejunkie05's Avatar
Im pretty sure the sticker on the swingarm calls for 42 rear and 36 front. I usually run 34 front and 36 rear give or take a pound or two. I like the way it feels. But that's just me.
Racejunkie05 is offline
post #4 of 26 Old 02-13-2011, 06:42 PM
Licensed Dist of HaterAde
TMY10ER's Avatar
Originally Posted by yb legal View Post
max? Nope, its a good starting point. Then you can adjust it for riding style and preference. Also each tire works better at different psi. Soem like higher for mileage, and not a lot of aggressive riding, while others want max grip and performance, which typically sacrafices mileage.
.......i usually run a little more air pressure in the rear and it seems to work for me. most call for 42psi i believe but i try to stay around 38 front and 34 rear but that differs from time to time and depending on the weather and tires i'm using.
TMY10ER is offline
post #5 of 26 Old 02-13-2011, 08:06 PM Thread Starter
nfranke's Avatar
ok, they asked me when i changed tires, I never really put much thought into and always ran what was on the sidewall, I knew lower psi would give more grip but never connected the dots that more would give you better mileage
nfranke is offline
post #6 of 26 Old 02-13-2011, 09:15 PM
I think I'm running 35 front and 37 rear.
IceZX7R is offline
post #7 of 26 Old 02-13-2011, 09:30 PM
jeffdort's Avatar
frankie, what tires did you get ? what type of riding is typical for you? climate conditions?
my pressures are just above 30 , i run pirelli rosso corsa , i dont use the bike much on the highway or for commuting, mainly curvy backroads on nice sunny days when the road is warm as well.
grip is more important to me than lifespan
measure when cold!
jeffdort is offline
post #8 of 26 Old 02-13-2011, 09:42 PM
Guilty by association
CP10R's Avatar
Originally Posted by racejunkie05 View Post
im pretty sure the sticker on the swingarm calls for 42 rear and 36 front. I usually run 34 front and 36 rear give or take a pound or two. I like the way it feels. But that's just me.
CP10R is offline
post #9 of 26 Old 02-13-2011, 10:04 PM
Supercharged Mod
The "official" and "legal" recommendation is the pressure in the owner's manual or on the tire information label on the vehicle. The upper range is fine for riding in straight lines down the highway while carrying a passenger ...
For track days, you should go with the recommendation of the tire manufacturer for the tire that you are using. It's common for this to be approximately 30 psi front and rear. Some types of rear tires require pressures as low as 23 psi. In some cases this pressure is to be set after the tires are on tire warmers at a specified temperature for a specified time. NOT simple.
For twisty-roads riding, take the tire pressures recommended for track days and add a couple. It will be lower than the owner's book recommends, and that will be lower than the max recommended on the tire sidewall.
I use 32 front / 32 rear with Michelin Pilot Power tires.
GoFaster is offline
post #10 of 26 Old 02-13-2011, 10:09 PM Thread Starter
nfranke's Avatar
I have q2's, the majority is straight but i like to ride the curves also, i ride the ohio river several times a year, but I usually only get about a mile of good curves on my way back and forth to work
nfranke is offline
Tags
air pressure, pressure, tire, tire pressure, tires
Oil pressure?? Gunbunny Performance and Tech 4 11-17-2010 09:29 PM
Tire Pressure 09zx10miami Performance and Tech 20 09-23-2010 09:39 PM
Tire Pressure Fast10 Performance and Tech 15 08-14-2006 11:54 PM
Under Pressure!! BenRyDn The ZX-10R 11 04-07-2005 07:59 AM
Can’t take the pressure. evander The ZX-10R 10 08-21-2004 06:05 PM
