Air fuel ratio ? - Kawasaki ZX-10R.net
post #1 of 19 Old 12-27-2008, 08:16 AM Thread Starter
eazy_zxrr's Avatar
Air fuel ratio ?
Does anyone know the best recommended air fuel ratio for the 06-07 zx10 ?
eazy_zxrr is offline
post #2 of 19 Old 12-27-2008, 09:42 AM
Supercharged Mod
There is no single number that can answer this, and any attempt to map it to a single air/fuel ratio throughout the entire range of load and RPM will not give best results.
At part load you want around 15:1 for best fuel consumption and to not wash oil off the cylinder walls with excess fuel. At full load you want 13-ish. A few tenths one way or the other will make scarcely any difference.
GoFaster is offline
post #3 of 19 Old 12-27-2008, 10:00 AM
SpazOnaZX's Avatar
....it depends on how you measure it too. Measured on a stationary dyno, we mapped down to 13:1 WOT and it felt prety good. I actually had it mapped 12.5:1 from 9K rpm up (for a small nitrous shot) and it picked up trap speed consistantly in the 1/4 mile WITHOUT the nitrous.
Ivan mentioned this in another thread, and I have to agree with him: the A/F line should be a slightly down sloping line (measured from left to right...) at WOT... starting in the neghborhood of 13.:1. :)
As for the rest of the map (sub WOT).... good luck with that. It's a pretty complicated affair that is better seen in person the first time (IE: find a good dyno tuner!).
SpazOnaZX is offline
post #4 of 19 Old 12-27-2008, 02:55 PM
magzx12r's Avatar
Is 15:1 not too lean?
Mark
magzx12r is offline
post #5 of 19 Old 12-27-2008, 05:34 PM
Speed Freak
garth285's Avatar
for wide open throttle it is.... the leanest I'd go is 13.3 for wide open cruising speeds about 14.5:1
garth285 is offline
post #6 of 19 Old 12-27-2008, 06:21 PM Thread Starter
eazy_zxrr's Avatar
so the factory ecu's dont have an set ratio ?
post #7 of 19 Old 12-27-2008, 08:52 PM
Speed Freak
garth285's Avatar
they do but they will vary with mods we dont have a closed loop system so the bike never knows what kinda of air fuels the ecu is making the bike have.
garth285 is offline
post #8 of 19 Old 12-27-2008, 09:50 PM
edouble's Avatar
Are you talking about Ivan at Ivan's Performance?
edouble is offline
post #9 of 19 Old 12-28-2008, 09:37 AM
Supercharged Mod
In cruising conditions, where the engine is running at a small fraction of its rated power (read: heat) output, you are never going to burn a valve, and unless the ignition timing is way out of whack, you are never going to run into detonation.
Best fuel consumption is normally in the 16:1 range, but with conventional ignition systems, that's flirting with misfire particularly when engine load suddenly changes, and 15:1 will give a better margin against that.
Your car has a closed-loop EFI system that runs it at 14.7:1 throughout almost the entire speed/load range - everywhere except full throttle high revs. The engine in your bike is fundamentally no different.
Remember the Honda Insight? Under steady throttle conditions, those ran as lean as 24:1 ... but they would go to 14.7 the moment the engine load changed to avoid misfire.
GoFaster is offline
post #10 of 19 Old 12-28-2008, 04:55 PM
SpazOnaZX's Avatar
yea... he mentioned it in one of his TRE threads.... about the 08 I think. It pretty much applies to any ram air bike IMO. I've seen the actual results from doing somyself; that usually makes me a believer.
A/F Ratio with A&R Baffle Kit holeshot34 Performance and Tech 2 09-18-2008 08:44 PM
Wego II, Air/Fuel Ratio Metering System rated zx Parts, Gear and Accessories 4 06-13-2008 01:46 PM
air-to-fuel ratio RaceAir Performance and Tech 3 11-06-2007 11:36 AM
Air/Fuel ratio question bigpunr1 Performance and Tech 2 09-06-2005 11:00 AM
A/F Ratio miykl Performance and Tech 4 01-10-2005 09:13 AM
