aftermarket shift light - Kawasaki ZX-10R.net
post #1 of 12 Old 07-02-2010, 08:02 PM Thread Starter
gazx10's Avatar
did a search, but found nothing conclusive. where can i find tach signal for shift module? do i tap coils, or guage wires? also anyone know how accurate stk. shift light is. thanks. 04 zx10.
gazx10 is offline
post #2 of 12 Old 07-03-2010, 01:03 AM
jdgun_13's Avatar
Send a message via Yahoo to jdgun_13
standard shift light is more than likley off like the tach is 500-700rpm at redline.
you could opt for the plug and play unit from accumen, $55 harness and then the shiftlight they sell..
this would be the eaasy way, but if you looking to tap into anything then it would be the tach signal coming into the gauge, have done this on a 6r...
jdgun_13 is offline
post #3 of 12 Old 07-03-2010, 11:58 PM
Licensed Dist of HaterAde
TMY10ER's Avatar
and i've been wanting one of those accumen lights for a while....i thought they stopped making them? i WILL be looking into it now though.
Take a risk, and you may lose. Never risk, and you will always lose.
TMY10ER is offline
post #4 of 12 Old 07-20-2010, 11:41 PM
Newfie Bullet
craig_sez's Avatar
Images: 34
you want shift lights..here go all out and be cool at the next time you do yer local coffee shop chit chat..Its plug and play too..
http://www.baysideperformance.com/in...Path=2015_2013
craig_sez is offline
post #5 of 12 Old 07-21-2010, 07:34 AM
At what RPM on the Tach does the factory rev limiter kick in on an 04 10? I have the factory shift light set at 13,000 and yet I never bump the rev limiter when shifting. In fact, sometimes I actually wait a little time before shifting after seeing the shift light come on. My bike makes peak HP right at the rev limiter, so I want to shift as close to the rev limiter as possible. Thanks for the help. Mike.
880turbo is offline
post #6 of 12 Old 07-21-2010, 09:16 AM
Dark_'s Avatar
If you have a PCIII and the Hub you can wire an LED to one of the 2 Hub 12V outputs and program it as a shift light.
-Ryan
06 ZX10r
Dark_ is offline
post #7 of 12 Old 07-21-2010, 09:26 AM
jcw
Just in my opinion, I've been through a bunch of shift lights and think the best ones are sequential shift like in rally cars and formula one.
Ishift from ecliptech looks nice. I haven't bought one yet, but probably will.
jcw is offline
post #8 of 12 Old 07-21-2010, 09:31 AM
dsabat's Avatar
I use a Stewart-Warner Ultra shift light with digital tach on both bikes. One cost me $40, the other $70.
dsabat is offline
post #9 of 12 Old 07-21-2010, 08:22 PM Thread Starter
gazx10's Avatar
signal?
already have a dynatek shift module and shift light, just asking for scource of tach signal. thanks.
gazx10 is offline
post #10 of 12 Old 07-21-2010, 08:48 PM
bluedevil's Avatar
tach signal is at the connector of the Instrument Cluster(tach readings are not as accurate as picture below......tapping coils for tach signals is for real Guages like an Autometor ....this one required tapping at the coils but with a special harness and high powered diodes:
bluedevil is offline
ZX10 Kit Shift light? (or aftermarket) TENN10 Performance and Tech 3 05-01-2010 07:32 PM
shift light DEATH_INC. The ZX-10R 7 09-12-2009 01:30 AM
Shift Light pumkinkiller Parts, Gear and Accessories 7 01-30-2008 05:42 AM
Better shift light?? sxi The ZX-10R 27 01-17-2007 07:24 AM
Shift Light Salesguy10r The ZX-10R 33 07-18-2006 07:03 PM
