Advice: Oil drain bolt - Kawasaki ZX-10R.net
post #1 of 30 Old 10-19-2009, 05:54 PM Thread Starter
Stealth Rider's Avatar
Question Advice: Oil drain bolt
I was doing my oil change today and when I went to screw back in the oil drain bolt, it just kept threading in and never stopped turning. I turned it a couple times then take it out and metal shaving from the thread on the inside of the oil drain pan start coming out. What can I do to fix this? Should I buy a longer bolt? Or do I have to buy a whole new oil drain pan thing?
Any advice is appreciated
"The world is made of two types of people: riders and everyone else. In a country full of lawsuits, threat levels, child proof caps, rules and regulations, owning a motorcycle is one of the last ways to give the middle finger to society's expectation that we constantly be caged and protected. We all want our machines to be a representation of ourselves. Those that ride know being on a motorcycle is not just about getting from point A to B."
John Zamora - Super Streetbike
Stealth Rider is offline
post #2 of 30 Old 10-19-2009, 06:54 PM
Tee's Kawa55's Avatar
Get a new oil pan...or you might be able to have the hole re-threaded but I doubt it
DDM Tuning HID lights| Sportech Windscreen| ASV shorty levers| Driven D3 grips| Evotech 1/4 turn gas cap| LSL sliders| Woodcraft case covers| PCV with custom map| BMC race filter| secondaries removed| EK 525 red chain| Vortex rearsets| M4 Slayer exhaust| PSR chain adjusters| Speigler brake lines| custom front and rear seat| Pro bolt aluminum bolt kit| Hellrazor servo eliminator
Tee's Kawa55 is offline
post #3 of 30 Old 10-19-2009, 07:02 PM
10rmotor's Avatar
You've obviously stripped it, so a longer bolt won't help as there aren't any threads left for a bolt to grab. Your cheapest solution is to put a helicoil in it, being careful to get all the aluminum shavings removed before sealing it up.
10rmotor is offline
post #4 of 30 Old 10-19-2009, 07:04 PM
How do people keep doing this? Screw it in with your fingers...
26606 is offline
post #5 of 30 Old 10-19-2009, 07:27 PM
I think a lot of people are afraid of the drain bolt coming out and go all incredible hulk and tighten the sh!t out of it. Best thing for them would be to get a wrench (or ratchet) about 4 inches long to keep themselves under control.
They could always take a lessen from racers and buy a spool of safety wire.
After my son stripped several threads, I asked him WTF he was doing. He had a 1/2 inch torque wrench on a bolt that needed 89 inch pounds. Never mind that the 1/4 inch torque wrench was still in the tool box. Good news is I now have a full assortment of helicoils.
TN10R is offline
post #6 of 30 Old 10-19-2009, 07:31 PM
Might want to try these:
http://www.timesert.com/
I've never used them, but I've heard claims they are better than helicoils.
I'd take the pan off before doing this. Don't see how you could keep the shavings out of there otherwise.
If you have never cut new threads before, I would find someone who has to help. It's not hard but you don't want to be learning on your drain pan.
TN10R is offline
post #7 of 30 Old 10-19-2009, 07:42 PM
ronnulph's Avatar
Send a message via Yahoo to ronnulph
That looks pretty solid. Good luck with whatever you choose to do.
08 ZX10
ronnulph is offline
post #8 of 30 Old 10-19-2009, 07:47 PM
RDLYN13000's Avatar
Images: 38
RDLYN13000 is offline
post #9 of 30 Old 10-19-2009, 07:47 PM
5-F Dawg's Avatar
dont feel so bad man next time start it by hand especially bolts like that....ive done stuff very similar...your best bet is probably re-thread it or buy a new oil pan with a new bolt and washer:)
BOOM!!! SHAKE AND BAKE
5-F Dawg is offline
post #10 of 30 Old 10-19-2009, 07:52 PM Thread Starter
Ive only tightened it at manual service recommendation torque. Ill probably just buy a new pan. Anyone know where i can buy a new one at?
oil drain plug cnote The ZX-10R 2 02-07-2008 03:36 PM
Check your oil drain plug!!!! Dan Performance and Tech 20 08-27-2007 01:14 AM
Oil drain plug Jax 10 Performance and Tech 2 03-17-2007 11:53 PM
Oil Drain Bolt ? RickRoush03 Performance and Tech 14 02-23-2007 05:07 PM
Coolant drain bolt safety wire pics!!! zx10ragentblack Test Area 3 04-29-2006 10:32 PM
