Adjusting rev limiter - Kawasaki ZX-10R.net
post #1 of 15 Old 07-23-2010, 10:31 PM Thread Starter
stretched10R's Avatar
I have a 06 zx10 and want to turn the rev limiter up to about 13.5,I need about 10 more ft worth to finish out the quarter mile with the gear I am running.Can I adjust it with a power commander on a laptop or do I need something else??
Born with that MAD KAW DISEASE!!!!!
stretched10R is offline
post #2 of 15 Old 07-23-2010, 11:51 PM
JLAudio11's Avatar
Either get pc hub, ignition module and beg dynojet to give you a code to extend it and hope it works, or call guhl motors and send them your ecu. They're the only ones selling the zx ecu hack technology. These are basically the only options out right now.
'06 "Corn Burner" Edition ZX10R
w/ a lot of bolt-ons
PERFORMANCE CYCLE 2 Racing
JLAudio11 is offline
post #3 of 15 Old 07-24-2010, 12:00 AM
bluedevil's Avatar
yeah, that would suck to hit the rev. limiter 10ft or any feet before the finish line.....I have done it only at the finish line but would need to do changes if it happens before that.
bloo
bluedevil is offline
post #4 of 15 Old 07-24-2010, 01:53 AM
redline659's Avatar
Just have guhl flash your ecu with what you need
redline659 is offline
post #5 of 15 Old 07-24-2010, 02:06 AM
Dont mess wit White Ninja
abzx10r's Avatar
Why not change up the gearing...Wouldnt that be cheaper? Seems to me your geared and revn before the traps...gearing, or like the guys said above, flash the ecu!
abzx10r is offline
post #6 of 15 Old 07-24-2010, 06:29 AM
Lougots's Avatar
If your going ~140 mph you cover 10' in less than .05 seconds. Anything you do in the last 10' isn't going to change your time. It's probably way more than 10', no?
Green '04
Lougots is offline
post #7 of 15 Old 07-24-2010, 07:10 AM
Dark_'s Avatar
quick shifter..should get you in to that next gear sooner than you would get in to it currently.
-Ryan
06 ZX10r
Dark_ is offline
post #8 of 15 Old 07-24-2010, 08:30 AM
bugman53's Avatar
an air shifter takes around 50-70 mili sec to shift so by the time you get into that next gear the race will be over. I would drop a tooth on the rear sprocket. or have the ECU hacked.
High Velocity Cycles 2005 Ti ZX10R
Greeensboro NC
bugman53 is offline
post #9 of 15 Old 07-24-2010, 10:48 AM Thread Starter
Im hiting the limiter in 6th on spray before I go thru the traps atleast 10 ft left.I love the gearing I am running,the bike 60ft's great,Running 8.80's 160 having to let off.-1 +4,Damn I wish the limiter was easiar to turn up
post #10 of 15 Old 08-21-2010, 08:07 AM
bugman53's Avatar
I would just do -1 +3 and call it a day.
Greeensboro NC
bugman53 is offline
rev limiter at 11,000 tone.r Performance and Tech 10 05-19-2009 06:08 AM
Rev limiter bgmagma10 Performance and Tech 7 06-17-2007 10:14 AM
06 10R Rev Limiter BigDally The ZX-10R 21 07-06-2006 02:19 AM
where exactly does the rev limiter come in? busaforhire The ZX-10R 22 07-11-2005 11:32 PM
Rev limiter 96dragshee Performance and Tech 9 02-01-2005 07:42 AM
