adjusting 08 rear shock preload - Kawasaki ZX-10R.net
post #1 of 3 Old 12-05-2008, 05:39 PM Thread Starter
spikespiegel's Avatar
Send a message via AIM to spikespiegel Send a message via Yahoo to spikespiegel
Hey guys, quick question on how to adjust the preload on the rear shock for the 08s. I weigh 165 lbs atleast with gear and I need to tighten up the preload a bit.
I know that the top ring has to be loosened counterclockwise with the help of that special tool for suspension or with a flat head/hammer...
So once this top ring is loosened, do i use the flathead/hammer combo to adjust the bottom ring? What constitutes an adjustment, a full rotation? Clockwise for stiff, counter for looser?
Any advice appreciated!
spikespiegel is offline
post #2 of 3 Old 12-06-2008, 05:49 PM
Azzkker's Avatar
stiff is CW, light is CCW, and take it in little steps when adjusting. i usually do 1/2 turns then measure, till i get close on the rear sag. it doesn't take much to make a big difference. i use white out to mark the original positions on the preload collars so i don't lose track.
2008 zx-10r: black cox racing guard, puig db, pipercross race filter, Akra EVO CZ, brocks strap, airbox silencers removed, champs chain adjusters, assorted Ti bolts, PCV, Auto tune
2003 636: akra EVO, kit ecu, bmc race, penske double, traxion forks, galfer rotors, pads, lines, puig db, race railz, factory pro velocity stacks, shift star kit, H.I.D projector retrofit, D.I.D evr3/ 14/40 stealth sprocket, vfx taillight, pc3
Azzkker is offline
post #3 of 3 Old 12-06-2008, 07:45 PM Thread Starter
thanks Azzker!
Tags
08 rear shock, adjustment, preload
adjusting rear preload on the 08 Red_ninja The ZX-10R 22 08-11-2008 01:17 PM
Doubt on rear preload Velociraptor Performance and Tech 5 06-06-2008 09:44 AM
Rear preload/sag Abiagi The ZX-10R 9 10-11-2006 03:01 AM
Tool needed for adjusting rear preload Jahna The ZX-10R 5 01-03-2006 06:28 PM
Rear Preload tool bollert The ZX-10R 5 07-08-2004 08:54 AM
