Adjust TC while moving - Kawasaki ZX-10R.net
post #1 of 4 Old 06-18-2019, 09:45 PM Thread Starter
Is it possible to change traction settings while in motion?
Is it possible to default to TC off? or at least remember previous traction setting?
Gen 5 with Woolich.
Thanks
MillyMacKenzie is offline
post #2 of 4 Old 06-18-2019, 10:13 PM
You can set the traction control to any setting but off while moving. I've not seen a way for woolich to mod it so that so you can turn it off while moving. If you turn TC off, cycling the key brings it back to 1. Again, not seen a way to change that in woolich. It will remember any other level you set it at. Race ECU/Harness might do it. Dunno.
palomartian is offline
post #3 of 4 Old 06-19-2019, 05:26 AM
Formerly CLCRACINGAaron
Neonmarine's Avatar
You might need to have the throttle closed while moving to adjust the TC setting on the stock ECU. KIT ECU allows full throttle TC adjustment while moving.
"You must subsume yourself to the bike"-Casey Stoner
"There’s a moment when a rider needs to stop thinking about technology and just twist the throttle."-Pit Beirer, KTM Motor Sport Director
Neonmarine is online now
post #4 of 4 Old 06-19-2019, 07:05 PM Thread Starter
I was hoping to be able to turn it off while moving, appears thats not an option. Thanks gents
