Gen 4: 2011-2015 ABS removing - Kawasaki ZX-10R.net
post #1 of 5 Old 04-13-2011, 06:49 AM Thread Starter
ABS removing
Gday everyone. Has anyone had any luck bypassing their ABS for race bikes, i am thinking of removing mine but i would like to hear from someone who has attempted this already. I dont know if just removing brake lines and fitting some braided lines is the answer. Im sure some ABS fault codes will come up.cheers.
ben20 is offline
post #2 of 5 Old 04-13-2011, 08:54 AM
SkyDork's Avatar
I've heard you can just pull the fuse to disable the system for when you're on the track.
#WordCrimes
SkyDork is offline
post #3 of 5 Old 04-15-2011, 02:01 AM
Я - Ребенок Люциферов
Vonstallin's Avatar
Images: 16
yeap...just unplug the fuse and you are good to go. I think its the fuse in the back seat area.
Vonstallin is offline
post #4 of 5 Old 04-15-2011, 11:41 AM
BANNED
or you can buy a non abs bike?
hellboytt is offline
post #5 of 5 Old 04-15-2011, 01:22 PM
Supercharged Mod
What happens if you simply leave it connected?
Normal riding on the track should be below the ABS threshold ... unless you screw up, in which case, having the ABS ought to be better than not having it.
Local BMW S1000R racers last year were running them with traction control "off" but ABS engaged. On that bike, the ABS does some automatic front/rear brake bias that are a good thing to be doing anyway, this way the rider doesn't have to concern themselves with it.
GoFaster is offline
Gen 4: Removing Cat ggenovese Performance and Tech 12 04-03-2011 01:55 PM
removing air box codyc_13 The ZX-10R 7 03-16-2008 08:15 PM
Removing gas cap -No Key Bigtuna660 The ZX-10R 35 11-04-2007 07:00 PM
Removing Cat what map will i need ? Speedyj Performance and Tech 7 11-16-2006 02:18 AM
Removing your CAT smason5 Performance and Tech 19 08-20-2006 11:32 PM
