Gen 4: 2011-2015 ABS light - Kawasaki ZX-10R.net
 2Likes
  • 1 Post By Kawasaki Brad
  • 1 Post By Doppler
post #1 of 4 Old 01-22-2019, 02:03 PM Thread Starter
Jbsmooth's Avatar
ABS light
Has anybody else had an issue with there ABS light staying on? Ive done the basic trouble shoot batt disconnected, switch different modes, check the wheels for any thing out of place , unplugged.Its a 14 with around 4k .. thanks J.Humph
Jbsmooth is offline
post #2 of 4 Old 01-22-2019, 03:14 PM
belkins's Avatar
I've seen other gen4 do this when the battery is not providing the correct voltage. If that is not the problem then you should be able to pull the code that is triggering the light to stay on.
Also may want to check the fuses.. i believe there is 2 for the abs.
2013 Kawasaki Ninja ZX-10R
~Woolich ECU Flash/Log Box/AutoTune~Driven Block Off Plates~Woodcraft Frame sliders~Cox Radiator Guard~OEM Seat Cowl~Tinted Hotbodies Venom Windscreen~Lightech Chain Adjusters/Axle Sliders/Spools~Sato Rearsets/Race Hooks/Bar Ends/Reservoir Covers~Pazzo Shorty Levers~Engine Ice~Motodynamics Rear Turn Signals~Ohlins TTX MKII Rear Shock~R&G Case Savers~M4 Street Slayer Exhaust~Ohlins Race SCU~-1 +2 520 Driven Sprockets~520 DID Gold Chain~
belkins is offline
post #3 of 4 Old 01-22-2019, 04:07 PM
Kawasaki Brad's Avatar
+1 on battery. Stock one's are very poor quality. Most of the time this is the issue.
The encoders can get chunks of road debris or insects caught in them. Make sure all the slots are clear.
In rare cases the sensors have been known to come loose. Retorque the bolt that holds them on. Better still is to remove the bolt, apply loctite, and retorque.
michael4012 likes this.
Kawasaki Brad is offline
post #4 of 4 Old 01-22-2019, 07:49 PM
Doppler's Avatar
What these guys said. More specifically, it's likely to be the steering damper warning that shows first rather than the ABS (Same light but has ESD or similar in the LCD next to it.)
Kawasaki Brad likes this.
-Woolich/Race Tools/Log Box V3|-Graves Titanium/Carbon cat eliminator|-Ohlins Mechatronic|+2 rear|More stuff + stone chips & bugs
Doppler is offline
Gen 4: ABS vs Non-ABS KAWI KILBURN The ZX-10R 56 05-10-2014 06:18 PM
2011 How to tell from ABS n non ABS rider4life The ZX-10R 22 11-17-2011 10:17 PM
Gen 4: Abs or no abs? saigono1 The ZX-10R 7 09-22-2011 06:16 AM
2011 ABS or No ABS? The Nam3less The ZX-10R 71 01-21-2011 08:26 AM
2011 zx10r abs and no abs here comerbc5 Welcome Newbies! 1 11-23-2010 03:52 PM
