7,000 miles any service I need to do??? Help Please - Kawasaki ZX-10R.net
post #1 of 10 Old 02-10-2010, 09:16 PM Thread Starter
xx8055NIACxx's Avatar
Ok guys
I got my bike at 2,500 miles
got no manual with it, I did oil changes every 2,000 miles or so with synthetic repsol oil and filter
now I have about 7,000 miles, put on new tires and wondering, do I have to get the bike serviced at that mileage
the bike runs fine and starts like it always has
thx guys
Puig Screen, Carbon Scorpion Slipons, Starrotors HID, Champs Sliders, Targa Fender Eliminator, GIPRO/ATRE, Rim Stripe, CRG Shorty Levers, Galfer SS Lines. ZX14 Nissin Calipers, Puig Carbon Rear Fender, Attack Racing Carbon Front Fender, Vortex Mirror Blockoffs, Oberon Barend Mirror, BMC Race Air Filter, Carbon Fiber Heel Guards, Stomp Grip, Speedo Healer, 16t front Sprocket
xx8055NIACxx is offline
post #2 of 10 Old 02-10-2010, 09:40 PM
lowkey420's Avatar
you're
lowkey420 is offline
post #3 of 10 Old 02-10-2010, 09:50 PM
conspiracy's Avatar
Leave it alone until about 16k when you check the valve clearance. Other than that just keep on doing what you're doing, might want to lube the clutch cable. Your oil change might be a little overkill changing at 2k, 3000 miles should be just fine.
conspiracy is offline
post #4 of 10 Old 02-10-2010, 10:17 PM Thread Starter
thx guys
you guys are the best, will lube the cable, do I just put some grease on the cable right by the lever
post #5 of 10 Old 02-10-2010, 10:22 PM
lowkey420's Avatar
i'm dreading my up coming 16,000 mile service up
been hearing its expensive
post #6 of 10 Old 02-10-2010, 10:56 PM Thread Starter
hwo much money are we talking about here guys
post #7 of 10 Old 02-10-2010, 11:07 PM
Dont mess wit White Ninja
abzx10r's Avatar
^^^You could change your plugs but I highly doubt you need to...
I just rolled 8500 on mine and I did a oil change,brake pads, plugs, coolant to wet wetter, filter, tires, brake fluid the works and it was over kill...But I treat my baby good
2000 miles is over kill like said above, think 25-3500 every oil change...16,000 miles I would think hes doing a complete valve adjustment along with everything I said above
abzx10r is offline
post #8 of 10 Old 02-11-2010, 01:05 AM
Never use grease on your cables. It will only attract more crude and cause more problems.
There are various spray types that do a fair job. You can get a tool that clamps on the cable to keep it from going everywhere.
Never use anything that remains sticky and doesn't dry. Like grease, it will make things worst over time.
A little graphite is all I would ever use around the throttle housing. Can also be used on the cables.
Every year or 2 I remove the cables
(clutch and throttle) and let a 3in1 type oil drip and few drops at a time until it appears out the other end. Remove any excess, let dry completely and reinstall.
TN10R is offline
post #9 of 10 Old 02-12-2010, 04:58 PM Thread Starter
thanks brotha, this is why this site is the best, so much knowledge on here.
post #10 of 10 Old 03-25-2010, 10:51 PM Thread Starter
hey guys, brake pads, how often do you change yours
I have 8,000 miles and I have the HH pads
I can hear some squeeking at the beggining when I just start the ride, once they warm up they feel fine
thx
15,000 miles RDLYN13000 The ZX-10R 11 07-24-2009 10:20 PM
12,000 mile service - Anyone done it personally buckshot Performance and Tech 9 07-17-2009 11:44 AM
1 year and 4,000 miles later... SkyDork Pictures and Videos 5 02-25-2007 11:35 PM
30,000 miles Older Guy The ZX-10R 25 12-05-2005 07:53 PM
1,000 MILES!!! SacCityZ The ZX-10R 11 05-21-2004 01:12 AM
