636 sprocket - Kawasaki ZX-10R.net
post #1 of 11 Old 04-16-2006, 09:13 PM Thread Starter
norcal10's Avatar
636 sprocket
just wondering if a stock 05 zx-6r sprocket will work on my 10r. i got one of ebay for under 10 bucks; its a 43 tooth. am i gonna need a different chain? i know the 636 uses a 520 chain, didnt know if that makes a diff. i would love to be able to just throw this one on for now, moneys kinds tight right now so i cant get the 520 chain conversion. thanks guys.
norcal10 is offline
post #2 of 11 Old 04-16-2006, 09:29 PM
WOODYZX10R's Avatar
if it is a 520 sprocket it needs a 520 chain, if i am right the stock chain is 525
2004 ZX10R, mostly kinda stock
WOODYZX10R is offline
post #3 of 11 Old 04-16-2006, 09:41 PM
Big Daddy's Avatar
Images: 38
Originally Posted by norcal10
just wondering if a stock 05 zx-6r sprocket will work on my 10r. i got one off ebay for under 10 bucks; its a 43 tooth. am i gonna need a different chain? i know the 636 uses a 520 chain, didnt know if that makes a diff. i would love to be able to just throw this one on for now, moneys kinds tight right now so i cant get the 520 chain conversion. thanks guys.
yes it fits and yes you'll need a 520 chain to fit it properly.
http://www.renthal.com/cw_master_page.asp?make=6
Big Daddy is offline
post #4 of 11 Old 04-16-2006, 09:43 PM
Brendan ZX-10R's Avatar
Images: 15
Send a message via MSN to Brendan ZX-10R
Stock 525!
It's A Speed Thing, You Wouldn't Understand
ZX-10R 2005 Black
Brendan ZX-10R is offline
post #5 of 11 Old 04-16-2006, 09:44 PM
Ruthless Racing's Avatar
Images: 9
You can use the 525 chain with the 520 sprockets.
Kenny Poppell
AMA Dragbike SuperSport #1000
2007 AMA Dragbike 1000SS National Champion
2007 1000SS 1/8th ET Record Holder 5.967
Best 1/[email protected] Best 1/[email protected] Stock Wheelbase
Special Thanks:
Performance Psycle
Richies Tires
http://www.XXXRacingFuel.com
http://www.SuperbikeSpecialties.com
http://www.Tsukigi.com
http://www.CycleConceptsRacing.com
http://www.myspace.com/ruthlessracing1
Ruthless Racing is offline
post #6 of 11 Old 04-16-2006, 09:55 PM
Big Daddy's Avatar
Images: 38
yes but a very bad idea as the sprocket will travel the width of the sprocket and wear it out quickly.
post #7 of 11 Old 04-16-2006, 10:45 PM Thread Starter
norcal10's Avatar
sprocket will travel the width of the sprocket? i'm confused. i'm gettin conflicting answers here. i know if a sprocket is worn it will wear out the chain faster, but my bike has 700 miles, and the sprocket is new. shouldnt hurt anything, right?
norcal10 is offline
post #8 of 11 Old 04-16-2006, 10:52 PM
Big Daddy's Avatar
Images: 38
yes it will travel the width.
In this instance when i say wear it out prematurely its because a 525 chain is wider than a 520 chain or sprocket so if you use a 520 sprocket (thinner) the chain will travel/move the width albeit small back and forth as opposed to traveling true with like sized components.
post #9 of 11 Old 04-16-2006, 11:00 PM
Dragone's Avatar
Images: 11
True, you would not be happy or cheaper in the end.
W.F.O.ing with style will bring life back into focus
Dragone is offline
post #10 of 11 Old 04-16-2006, 11:04 PM
Big Daddy's Avatar
Images: 38
Heres a DID chart. look at the pin length in mm for the 520erv3 and the 525erv and you'll notice a difference of some 3mm which is an indication of the link width however some of the other series chains are only 1.5mm diff.
http://www.didchain.com/specs.htm
Ok, my front sprocket was easy... -install with pics El Diablo Performance and Tech 122 04-02-2015 03:51 PM
Who's coming to the 636 from the 10R? SuicideMachine ZX-6R & ZX-6RR Archives 16 03-16-2006 10:15 AM
45T sprocket spoon Parts, Gear and Accessories 0 05-22-2005 03:38 PM
Installing 16 tooth counter shaft sprocket rickv Performance and Tech 3 04-21-2005 09:33 PM
Ok, my front sprocket was easy... El Diablo How To... 1 02-07-2005 11:10 PM
