520 Chain SUCKGRADE - Kawasaki ZX-10R.net
post #1 of 26 Old 09-16-2010, 12:44 AM Thread Starter
Kawboy1056's Avatar
520 Chain SUCKGRADE
Ok, so I decided to shed somemore weight off the ole girl and upgrade to a 520 front/rear sprocket and chain kit -1 on the front. I slapped it all on and made sure there was no binding and adjust tension on the new chain and decided I would terrorize the mountain road quick before I went home for bed. Well as we all know with a new chain, it throws grease everywhere, so when I got back to the garage, I started cleaning her off and did and after-ride inspection. front sprocket=flawless... Chain=flawless, Rear sprocket=Not so flawless... The peaks (pitch) of the sprocket looked like the old one I just took off with 10,000 miles on it. We all know how a sprocket is supposed to look when we inspect em, and trust me, this one isn't holding up.. There are no broken teeth yet, but that's sure to come. I am pushing 81.6 ft lbs of torque per the dyno, so I am not sure what the 520's are supposed to be capable of handling from DRIVEN, but this has me concerned.. I am supposed to be receiving another sprocket from Sam, another 10.net member in the next day or two, maybe I will have better luck with the one he sent.. Only thing I figure, is that the sprocket isn't HARD ANODIZED... Any suggestions?
Kawboy1056 is offline
post #2 of 26 Old 09-16-2010, 12:48 AM
Dont mess wit White Ninja
abzx10r's Avatar
Is it coated? and a 520 is a gram littler at best, nexted time just stick with the 525, it will hold up longer any ways...
take a pic lets see whats up....
abzx10r is offline
post #3 of 26 Old 09-16-2010, 01:20 AM Thread Starter
Kawboy1056's Avatar
I will get close ups of the sprocket tomorrow.. But I did snap one before I tightened the chain and took it for a Spin...
post #4 of 26 Old 09-16-2010, 01:32 AM
samurai10R's Avatar
I went with the vortex 525 hard coated
samurai10R is offline
post #5 of 26 Old 09-16-2010, 01:39 AM Thread Starter
Kawboy1056's Avatar
I should have stayed with the 525, but I didn't... So now I gotta find a worthy rear sprocket... CRAP!!!
post #6 of 26 Old 09-16-2010, 03:13 AM
jdgun_13's Avatar
Send a message via Yahoo to jdgun_13
run supersprox and you wont have this problem....
I swapped over to the 520 ERVIII and well i should of stayed 525 as i notice the chain just does not have the same service life as a 525 does..
And honestly i cannot feel any difference on the bike, but like yourself i am sure 80ftlbs and 170rwhp that bit of weight on a street/track bike makes NO DIFFERENCE.
jdgun_13 is offline
post #7 of 26 Old 09-16-2010, 03:43 AM
All show and all go 10r
JLG0987's Avatar
I've really always question 520s on liter bikes other than for racing. 600s no problem considering mine even comes with one. I've actually considered going to a 530 on my 10r.
JLG0987 is offline
post #8 of 26 Old 09-16-2010, 05:00 AM
TENN10's Avatar
Images: 145
Thats what you can expect out of a cheap aluminum sprocket. Doesn't matter what the pitch of the sprocket is.
I use the Vortex F5 PTFE hardcoated sprockets. No problems at all.
http://www.vortexracing.com/index.ph...x=8&submit.y=8
A little info.
http://www.vortexracing.com/index.ph...ory=Produ cts
I have some spare, unused sprockets that I may cut you a deal on if your replacement isn't any better.
TENN10 is offline
post #9 of 26 Old 09-16-2010, 05:26 AM
or10r's Avatar
^^^You gotta love a guy who has spare un-used sprokets just layin around the garage!
or10r is offline
post #10 of 26 Old 09-16-2010, 06:58 AM
cyclepuck's Avatar
You'll be fine with a 520 as long as it is hard coated or steel which I'm running right now.
cyclepuck is offline
need a stock chain OR any 525 chain for this bike! mityaz Wanted: Buy or Trade 4 12-13-2009 12:19 AM
WANTED: Chain links or cheap stock chain Patrick Wanted: Buy or Trade 2 11-25-2009 11:57 AM
Chain Breaker/Chain Press TL1000s Performance and Tech 15 11-22-2008 04:44 PM
Chain Tensioner for 160 link chain. SAkI Wanted: Buy or Trade 0 10-13-2008 01:57 PM
help chain and sprockets which ones are the best also a chain breaker streetfighter Performance and Tech 19 11-09-2006 07:31 PM
