5.5" rim on the 10R - Kawasaki ZX-10R.net
post #1 of 15 Old 02-14-2010, 08:01 AM Thread Starter
Strik33r's Avatar
5.5" rim on the 10R
has anyone ever tried this?? what are the pros, the cons, and the tyre size it would have to have? i saw a cheap set of brand new marchesini's on ebay, but not the right rim measure..
help me out here, should i grab them?
________
Squirting gushing
Strik33r is offline
post #2 of 15 Old 02-15-2010, 02:37 PM
BANNED
ZX10Rracer's Avatar
There are NO pro's…….. the cons are you will need to run a 180 tire and contrary to popular belief this is not a good thing to do because you need the contact patch a 190 gives you { this is why if your buying Dunlop race slicks it’s a 195 rear} more contact patch!
ZX10Rracer is offline
post #3 of 15 Old 02-15-2010, 02:52 PM
Speed Freak
garth285's Avatar
what are you going to be doing with the bike???
garth285 is offline
post #4 of 15 Old 02-15-2010, 03:29 PM
funny that you say that, because a wider tire will give you less of a contact patch! think about it, if 190mm has to fit on the rim bubles out in the "correct" profile, then trying to fir a 195 in the same space will cause it to bubble out more, creating less of a flat spot. just fyi
mityaz is offline
post #5 of 15 Old 02-15-2010, 03:33 PM
BANNED
ZX10Rracer's Avatar
No your wrong. just a fyi
this falls under the "contrary to popular belief " category
and this is why they make different sidewall profiles
and make 16.5 rims and on 16.5 rims you could run a 210mm race slick for a HUGE contact patch!!
post #6 of 15 Old 02-15-2010, 04:24 PM
RPG76's Avatar
Your statement is only true based around what width of rim the tire was meant to fit on. A 190/50 bubbles up on a 5.5 inch rim because it was designed to fit a 6 inch rim. All of the extra large racing tires where designed to fit the 6inch rim, so no problems there. There can be problems with rubbing swingarms, funky head shake, ect. but these are not a tire on rim problem.
05 ZX10r "the Mongrel": GP Suspension rebuilt forks, LE Penske double shock, 05-06 ZX6rr shock linkage, Brembo RCS MC, Nissin calipers (best mod for this bike!!!), Attack rearsets, Motion Pro Revolver throttle kit, ASV clutch lever, Champs sliders, smoked Zero Grav DB, Ti caliper bolts, CF fender, Renthal grips, Speedo healer, Maviryk MDA123 batt, Supersprox +3 520, That's it..... For now
190/55>190/50
RPG76 is offline
post #7 of 15 Old 02-15-2010, 04:26 PM
Speed Freak
garth285's Avatar
guys he might also not be looking to go full out race spec tires, maybe he just wants marchesini's.... if hes riding on the street I doubt he will care giving up a tenth of an inch of contact patch......
lets find out what hes looking to use the rims for
garth285 is offline
post #8 of 15 Old 02-15-2010, 05:10 PM
your getting ahead of yourself. im going off of the suggestion that wider tire will create larger contact patch. which, with all else being equal, it won't. variation in rim width, sidewall profile or tire diameter were NOT mentioned, ya dig?
edit:
dont mean to highjack the thread, carry on
mityaz is offline
post #9 of 15 Old 02-15-2010, 05:42 PM
BANNED
ZX10Rracer's Avatar
edit:
Well CLEARLY I was talking race tire! and even More clearly I was talking rim size! so I have no clue what your talking about!
post #10 of 15 Old 02-15-2010, 05:51 PM
you learn something new everyday. i wasn't aware that the dunlop slicks 195 had a 65 wall. i will shut up now.
mityaz is offline
04/05 6R rim on 04/05 10R cbolton69 Performance and Tech 1 11-04-2009 02:19 PM
What are the advantages of running a 16.5" rim? garth285 Performance and Tech 3 09-29-2007 06:49 PM
190 tyre on 5.5" rim kiwifruit Performance and Tech 5 02-21-2007 09:47 PM
04 zx-10r rim weights homeguard The ZX-10R 4 10-04-2006 08:23 AM
New 05 10R rear rim Dooganx1 Parts, Gear and Accessories 5 08-16-2006 06:07 PM
