3rd gen air duct - Kawasaki ZX-10R.net
post #1 of 3 Old 01-27-2010, 06:09 AM Thread Starter
caboose's Avatar
Send a message via MSN to caboose
3rd gen air duct
Since no one seems to know much about fitting the 3rd gen bodywork on a 1st gen, i'm hoping someone can give me some help.
If someone has a 3rd gen air duct loose, i'd really appreciate some dimensions and some pics. I've checked the online microfiche and the 1st and 3rd gen mounting points do look similar.
The height and width of the duct where it fits inside the frame and also the spacing between the bolts on each side. Those 3 dimensions are what's critical, if they match up or are close i'll look for a used duct to work with.
2010 10R Superbike
caboose is offline
post #2 of 3 Old 01-29-2010, 12:02 PM
ducatiryder89's Avatar
Images: 21
I was thinking about what I said in your other post and I should have said modify the upper bodywork to fit the stock 05 air duct. Its a matter of laying fiberglass or cutting some away. It would probably be easier then modifying an air duct. Unless of course the the 08-09 air duct bolts directly to the 04-05. Just a thought. The subframe would be your biggest hurdle.
2005 ZX10R Track Bike With Way To Much Sh*t On It!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
ducatiryder89 is offline
post #3 of 3 Old 01-29-2010, 01:23 PM Thread Starter
caboose's Avatar
Yea.
The intake on the 04 is a fair bit lower than then intake on the 08. Probably 2" or 3". Modifying the bodywork to move the intake lower would be a pretty big job. Splicing the rear part of the 04 duct to the front part of the 08 duct would be much less work.
Also, i'm not using the 08 tail. Just the upper and lower.
2010 10R Superbike
caboose is offline
3rd Gen track bodywork on 1st Gen? caboose Performance and Tech 46 05-06-2010 07:32 AM
3rd Gen Swinger on 1st gen ZX10R: Road test jdgun_13 Performance and Tech 1 07-21-2009 05:37 AM
WTB: 06-07 Gen 2 Faring Stay, Ram Air Duct loki-10R Wanted: Buy or Trade 3 06-21-2009 12:31 PM
Has anyone ever had the ram air duct that holds the nose of the 1st gen???? elitejstn39 The ZX-10R 13 11-17-2008 12:29 AM
Pictures of a 1st gen and 3rd gen ... badexample Pictures and Videos 19 04-02-2008 11:08 AM
