30,000 mile oil analysis - Kawasaki ZX-10R.net
post #1 of 12 Old 12-21-2005, 07:40 PM Thread Starter
Post Whore
Older Guy's Avatar
Here's my 30,000 mile oil analysis:
Yes, I should have changed it sooner...but figured factory recommends 5,000 miles - then 1,000 miles over 3,000 miles shouldn't be that bad...WRONG...the broken bones in my hands just caused me to put it off...
There has been a LOT of discussion on this forum on oil fiters. I have been using K & N, (easy to put on and take off with the nut on the end) but after some posting took a look at the Purolater Pure ONE and just looking at the two together, the PURE ONE is obviously a better filter than the K & N. This oil change got the K & N, but after 2,500 miles - I am using the PURE ONE...
I know, my bad...
30K oil report
Older Guy is offline
post #2 of 12 Old 12-21-2005, 08:00 PM
I'd like to see a test of oil in this bike at 1K miles and 2k miles to compare the rate of breakdown.
green 10r, Akro EVO 2, Hyperpro rsc, tre, pcIII, Puig DB, K&N, Purvision HIDs, Speedohealer, GONE
08 Ducati Hypermotard S GONE
08 Kawi Concours 14, Area P full sys, PCV, Flies out
speedfreak is offline
post #3 of 12 Old 12-21-2005, 08:37 PM Thread Starter
Post Whore
Older Guy's Avatar
That's possible...
post #4 of 12 Old 12-21-2005, 10:51 PM
ram360's Avatar
Send a message via AIM to ram360
how much to have them test it?
ram360 is offline
post #5 of 12 Old 12-21-2005, 10:52 PM Thread Starter
Post Whore
Older Guy's Avatar
$20.00 get free sample mailer from their web site.
post #6 of 12 Old 12-21-2005, 10:53 PM Thread Starter
Post Whore
Older Guy's Avatar
it isn't really breakdown...it is the pecentages of the materials...and the percentage hasn't changed...
post #7 of 12 Old 12-22-2005, 09:43 AM
This is the kind of information that I like. You ought to post that up on Bob is the Oil Guy in the Used Oil Analysis (UOA) section. There is very little on motorcycles. These guys will go through the analysis and maybe give you more information and maybe even some suggestions.
I am currently running Mobil 1 15w50 and PurOne PL14610 filter and a 3,000 mile change interval. I plan on going to the Mobil 1 5w40 SUV stuff at the next change because the transmission shifts clunky until it is warmed up.
swjohnsey is offline
post #8 of 12 Old 12-22-2005, 12:46 PM
RickRoush03's Avatar
for the pure one oil filter, the bike gets it, the ROUSH, and the Acura. all run Amsoil full synthetic also!
"Lead, Follow, or get the hell outta my way!!"
Blue 2004 ZX-10R
- 152.5rwhp 77.6rwtq - more than I need
Red 2003 Jack ROUSH Classic #8 of 50
- 375rwhp 381rwtq
RickRoush03 is offline
post #9 of 12 Old 12-22-2005, 06:45 PM
mach_man_187's Avatar
Gotta love the Amsoil!
If you're not living on the edge, your taking up too much space!
mach_man_187 is offline
post #10 of 12 Old 12-22-2005, 09:57 PM
Supercharged Mod
Steve, I'm looking at the test sheet now. It says the oil was Castrol 5w40. Was that the Castrol motorcycle-specific stuff? There is a Castrol Syntec of that viscosity, but as far as I've seen, it's only sold at VW dealers (it's a special blend for VW diesel engines).
Viscosity is down a little, but it's not bad. Fuel dilution is good. No antifreeze is also good.
Lead, tin, copper, and zinc are found in Babbitt plain-bearing metal (crank and rod journals) and the bronze bushings in the transmission. Zinc isn't useful for analysis, though, because it's an ingredient in the oil additives itself. Lead, tin, and copper are all low - good sign, means low bottom-end wear. By the way, the lead number is not useful for an engine that has been driven on leaded gasoline.
Chromium, molybdenum, manganese, and iron are ingredients of alloy steel - crankshaft, transmission gears, camshaft, cam followers, stuff like that. Iron is found elsewhere, so it's not useful. The others are all extremely low - again, low bottom-end wear, a good sign.
Aluminum can come from pistons or from the camshaft journals, since the camshaft runs directly in aluminum on this engine (as with most other bike engines). The iron that's left is likely piston rings, but it's pretty low.
Silicon comes from sand. Low level means your air filter is working OK.
Calcium, phosphorus, zinc, are oil additive ingredients, part of the oil itself. OK.
The somewhat high aluminum is the only concern I'd have with it.
GoFaster is offline
How to change your own oil & filter... El Diablo Performance and Tech 191 04-04-2016 03:10 PM
GB Scotts Oil Filter Solo-Moto-Parts Vendors deals 15 04-05-2005 06:58 PM
How to change your own oil & filter... El Diablo The ZX-10R 1 02-07-2005 11:28 PM
How to change your own oil & filter... El Diablo How To... 1 02-07-2005 11:28 PM
BREAK IN PROCEDURES FOR MAX HP TRUE OR FALSE? zixxer Archives 29 11-01-2003 12:43 AM
