2nd Gear Problems - Kawasaki ZX-10R.net
post #1 of 10 Old 01-01-2009, 12:56 PM Thread Starter
shotgun713's Avatar
2nd Gear Problems
Need help just some background info i bought an 2005 zx10 around september it was a crashed bike only damage was the side pulsing cover and rashes on plastic and exhuast all banged up
the problem is when in second gear if i give the bike gas it starts jerkin like it popiing in and out of gear dont kno how to explain it but it kinda clicks and the bike jerks in and out of gear
thanks in advance for anyhelp
"They Say At 100MPH Water Feels Like Concrete, Just Imagine What Concrete Feels Like At 100mph" - Nicky Hayden
shotgun713 is offline
post #2 of 10 Old 01-01-2009, 01:01 PM
Hated.Or.LoveIt's Avatar
Check your gas filter and or gas pump. am no expert but give it a try. they say to smell the gas tank if it smells bad something is up with the rust being pump into the pump.
Hated.Or.LoveIt is offline
post #3 of 10 Old 01-01-2009, 02:22 PM
jayizzo's Avatar
^^^ that or it could be damage to the clutch if it was drop on that side also??? My bro had the same problem with his sv650 you would have to skip 3rd gear and go straight to 4th.If not it would do what you have said.
ZX10R now i know why its called MONSTER
Go Ninja Go Ninja Go!
GIFSoup
jayizzo is offline
post #4 of 10 Old 01-02-2009, 03:04 AM Thread Starter
shotgun713's Avatar
the bike was droped on the right side correct me if im wrong isnt the clutch on the left on these bikes or opposite thxs for the help guys
btw thats exactly what i do i skip 2nd cuz i figure just not mess with it more
post #5 of 10 Old 01-03-2009, 03:22 AM Thread Starter
shotgun713's Avatar
bump .
post #6 of 10 Old 01-03-2009, 03:39 AM
FEELING LUCKY, PUNK ?
Lucky10R's Avatar
Images: 19
the clutch is on the right side
Lucky10R is offline
post #7 of 10 Old 01-03-2009, 03:41 AM
jblaze's Avatar
Images: 14
You may have a bad second gear or bad shift fork.
jblaze is offline
post #8 of 10 Old 01-03-2009, 05:06 AM
1g-10r's Avatar
I'm with Jblaze. It sounds like the shift fork is bad or the 2nd gear dogs are rounded off. If it was the clutch it wouldn't be a 2nd gear specific problem.
1g-10r is offline
post #9 of 10 Old 01-03-2009, 11:48 PM Thread Starter
shotgun713's Avatar
on average how much would a shift fork cost to replace or even all of second gear?? thxs for the replies guys
post #10 of 10 Old 01-04-2009, 11:02 AM
sweetride10r's Avatar
yeah i would bet its second gear going most shops charge about 1200-1500 to fix a tranny with parts and labor czuz motor has to come outa bike and cases split. if you do need a tranny get hard shift shafts new forks and send the tranny out to be back cut also run the factory pro shift star your trany will shift like butter. maybe even put a thin head gasket in since you have the motor out just throwing things out there.
bike is down for not but not out
turbo project is a slow go no money
Need some work done
call 586-214-2414
sweetride10r is offline
5th Gear Problems 10inja Performance and Tech 18 08-17-2008 08:00 AM
Race Gear / Riding Gear kawboy69 Parts, Gear and Accessories 8 05-17-2008 06:38 AM
GIPro Wrong gear problems pylon Performance and Tech 20 08-14-2007 11:59 AM
04 6th gear problems homeguard Performance and Tech 3 06-06-2007 12:12 PM
Gear/Clutch problems... hillcountry10r The ZX-10R 33 06-30-2005 07:14 PM
