Gen 2: 2006-2007 2nd butterflies ? - Kawasaki ZX-10R.net
post #1 of 8 Old 06-10-2011, 04:49 PM Thread Starter
eazy_zxrr's Avatar
2nd butterflies ?
what is the +/- of removing the 2nd dairy butterflies?
eazy_zxrr is offline
post #2 of 8 Old 06-10-2011, 05:08 PM
PushKartChampion's Avatar
secondary butterfly valves are under your air intake stacks in the airbox and control airflow to the throttle bodies. Throttle position does not necessarily reflect the same open position in the valves. rough example: 50% throttle = 30% airflow from valve depending on where you are in the rev range, FI maps etc. If you remove them you unrestrict your airflow a little bit because you only have your primary butterfly valves (underneath 2ndary) to control airflow. Correct me if I'm wrong guys. I think there is a thread on how to remove them on here somewhere. I personally haven't removed mine because I wouldn't think it would make that much difference for the effort plus I have a TRE which does pretty much the same thing.
BMC Filter/VStacks/PCIII/GiPro ATRE/Smog Pump delete/-1+2 520/Speedohealer/HEL SS Lines/Pazzo Shorties/Cox Grill
PushKartChampion is offline
post #3 of 8 Old 06-11-2011, 01:16 AM
Chris99sleeve's Avatar
If you search "secondary butterflies" its there as a poll and "how to".OP is hesaves. there are 76 effing pages that I read last night. some people swear by it, and others say it doesn't do anything.
the drawback is that you have to get the bike remapped and the throttle response is supposedly more sensitive ie: twitchy. it is possible that removing them can cause the fuel ratio to be dangerously lean without a tune.
the pro is that many people say the low and mid range feel way better. someone put it "the beast has been awakened." others say they feel a real difference at 6000rpm and above.
I decided not to take them out because I dont intend on remapping.
hope this helps, and many people would tell you to search more thouroughly next time.
cheers
Chris99sleeve is offline
post #4 of 8 Old 06-11-2011, 05:15 AM
Dont mess wit White Ninja
abzx10r's Avatar
cheers
mine was, but the gain was there on my dyno chart after tune:...
abzx10r is offline
post #5 of 8 Old 06-11-2011, 04:59 PM Thread Starter
eazy_zxrr's Avatar
i went ahead and removed them last nite n WOW!! the difference is nite n day the bottom end feels i went up 2 teeth in the rear n continues all the way to redline ... rec everyone remove there's
post #6 of 8 Old 06-11-2011, 05:31 PM
Licensed Dist of HaterAde
TMY10ER's Avatar
For anyone else who might be interested?
https://www.zx-10r.net/forum/showthre...ry+butterf ly
Take a risk, and you may lose. Never risk, and you will always lose.
TMY10ER is offline
post #7 of 8 Old 06-18-2011, 05:40 AM
Late Apex
Solo-Six's Avatar
Are you running a power commander? If so are you running a base map from the site .. I would get a tune .... lean conditions always make your bike scream.... but yeah they help a crap load ... my ride is already twitchy cause I have the R6 throttle tube for a 1/6 turn
________________Grip It And Rip It_________________
Solo-Six is offline
post #8 of 8 Old 06-18-2011, 05:44 AM
Late Apex
Solo-Six's Avatar
Sup brutha ? Guess what im getting next week? The under belly hardrock MotorSports HR1 Riot series pipe. They are here in spokane and doing it all up next week. Hitting the Dyno before and after so ill be posting another re jewelry ... and before you say it I know... im always like this though. Im never satisfied. Itsnever fast enough. It never looks good enough. Itsnever clean enough. Hahahahaha
Solo-Six is offline
butterflies RDLYN13000 Performance and Tech 21 07-16-2009 03:26 PM
Butterflies gone sy360 The ZX-10R 38 07-15-2009 11:13 AM
secondary butterflies Levi The ZX-10R 8 11-07-2008 07:43 PM
Map for removed butterflies ? kawiiiiii Performance and Tech 1 08-23-2007 07:53 PM
2nd set of butterflies.... Nevaeh Speed The ZX-10R 5 05-05-2007 03:54 PM
