2mm ?????? - Kawasaki ZX-10R.net
post #1 of 32 Old 01-18-2010, 07:51 PM Thread Starter
tone.r's Avatar
2mm ??????
2MM guy's how long did your 2MM last, what's some things to look out for doing a 2mm, if your bike is still going strong how many mile do you have on it?
stock rods, stock crank
Tone.R {checkmate}
Do what makes u happy whatever it is.....Roberson Racing
tone.r is offline
post #2 of 32 Old 01-18-2010, 08:46 PM
axo250's Avatar
Send a message via AIM to axo250
I have about 7k miles or so on my 3mm and it runs like a champ. Knock on wood of course.... I didn't deck the head. I put a thinner head gasket to slightly raise the compression but nothing drastic.
Didn't you bore yours? If so what's going on??
"Besides, my ZX-10R eats GSX-Rs for breakfast." -- SportRider Magazine Article
axo250 is offline
post #3 of 32 Old 01-18-2010, 09:43 PM
strkd50's Avatar
I'm also interested in the 2-3mm's as far as reliability. Also if anyone has any input on stroked cranks
2012 ZX-14R
#228
strkd50 is offline
post #4 of 32 Old 01-18-2010, 10:03 PM
beenthere's Avatar
Personally I believe the 2 mil is a better choice for durability without loosing anything to the very slightly larger 3 mil bore. The 2 mil will have a little better cylinder rigidity preventing distortion caused loss of compression. The 2mil will also have a bit lighter piston reducing mechanical inertia losses, probably will run a little cooler too. Stroker crank street motors seem to wear themselves out quicker than their stock stroke counterparts. The different rod attack angle of the more outboard rod throws side loads the pistons a bit more, maybe not a big issue for a bike thats ridden a 1/4 mile at a time but for a street bike it could in theory mean shorter engine life. The crank pins, on a stroker are welded and re-ground to achieve the offset that gives you the longer stroke. Some of these re-weld, re-ground pins have been known to flake metal and cause trouble. A stroker motor also has to have piston clearences checked at bdc as the piston is pulled further down in the cylinder and could cause the piston skirt to hit the crank throws. If I remember correctly the head might have to be shimmed to avoid contact with the piston crown due to its higher tdc travel. You could build a nice cammed 2mil over motor that would give you great bang for your buck or go hog wild with big everything complete with "sick" power but you might have to freshen the top and bottom on a regular basis. Just my 2 cents
beenthere is offline
post #5 of 32 Old 01-18-2010, 10:13 PM
strkd50's Avatar
Perhaps a cammed 2mil with a hint of nitrous?
2012 ZX-14R
#228
strkd50 is offline
post #6 of 32 Old 01-18-2010, 10:43 PM
JLAudio11's Avatar
couldn't have said it better myself
'06 "Corn Burner" Edition ZX10R
w/ a lot of bolt-ons
PERFORMANCE CYCLE 2 Racing
JLAudio11 is offline
post #7 of 32 Old 01-18-2010, 10:46 PM
beenthere's Avatar
A properly mapped, cammed, 2 mil over 10r motor would probably make 175rwhp. Add 36 hp nos and you got what....211? and the need of a longer swingarm
post #8 of 32 Old 01-18-2010, 11:12 PM
All show and all go 10r
JLG0987's Avatar
Is that a gen1 only? I see dyno sheets of the gen3 with full systems between 170-175rwhp or are these bullshit. I'd like to know as I'm waiting on my ti akra.
JLG0987 is offline
post #9 of 32 Old 01-18-2010, 11:21 PM
JLAudio11's Avatar
it's all relative man. Try to get your bike on a dyno before and then after. The difference will be what you're looking for. Think about how many variables come into tuning each specific bike. These all impact the number that come out of the dyno. Then add in the variables for the dyno. My best friend owns and operates a dyno. Give me a little time with your bike and I can show you a dyno sheet of your bike making 200hp.
post #10 of 32 Old 01-18-2010, 11:28 PM
Dont mess wit White Ninja
abzx10r's Avatar
^^^I had mine tuned last month or so...at work or I would load my sheet. base walking in the door with a pc/secondaries/filter/stacks/full exhaust was 165. something...Left at 169. something...Gained like 7hp in one part of my power band...Felt great...
abzx10r is offline
2mm ? tone.r Performance and Tech 7 12-09-2009 08:28 PM
2mm over map 11ute Performance and Tech 2 10-04-2008 07:22 AM
Trackday 2mm 7-9 @ T-hill, who's going?.... ZXTOM Race and Stunt 0 07-08-2007 01:23 PM
Garth285's 2mm over project garth285 Performance and Tech 138 05-06-2007 11:26 AM
2mm bore and 2mm stroke compression anyone? garth285 Performance and Tech 13 07-02-2006 12:43 AM
