211 pressures - Kawasaki ZX-10R.net
post #1 of 5 Old 05-16-2011, 05:38 PM Thread Starter
eck in fife's Avatar
211 pressures
dulop 211 s run a low psi than normal ...dosent work on road :headshake what psi do you guys run them at for fast road runs ....put 30/30 in still seems a bit weird the turn in is f nice totaly diff to the corsa 111.
eck in fife is offline
post #2 of 5 Old 05-16-2011, 10:00 PM
Guilty by association
CP10R's Avatar
30 front and rear on the road and less on the track with the gp211
General "Mad Dog" Mattis
CP10R is offline
post #3 of 5 Old 05-17-2011, 05:48 AM
EvoNinja's Avatar
I'm running 28psi front and 23psi read cold, for the road twisties. Any more than that and it doesnt feel planted. Its weird, its the first tire i got that i have to use less air in the back than in the front for the street.
For the track i use 26f and 18r ..
ZX-10R
>> scary fast
EvoNinja is offline
post #4 of 5 Old 05-17-2011, 11:32 PM
ducatiryder89's Avatar
Images: 21
Reason they feel weird is you're probably never getting those tires up to proper temp. I'm guessing since you are in in Europe you have a UK211. On the track typically I started 28 cold front and after an hour on the warmers adjusted to 30-32 depending on track temp. Rear started out 20 and after an hour 22-25 depending on track temp. For the street I would say start 28F 25R and see how it feels. But the Corsa III was a street tire and the 211 is a pure race tire they will turn in differently because of construction. Corsa III will have a smoother transition into a corner while the Dunlop will basically drop you on your face. Just my experience. Good luck.
2005 ZX10R Track Bike With Way To Much Sh*t On It!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
ducatiryder89 is offline
post #5 of 5 Old 05-18-2011, 05:39 AM
Ninja_10R's Avatar
to most of it.
To the OP - However in my opinion on the street, don't drop the front below 30psi as the front is not an ntec construction. Street riding, you may not be braking hard enough to heat up the tire to optimum pressure and at very low pressures, it may feel imprecise.
Ninja_10R is offline
Tyre Pressures Redbull Race and Stunt 1 05-28-2010 05:56 AM
Dunlop 209 N tec pressures fireman69 Race and Stunt 4 02-24-2009 08:38 PM
Tired Pressures. spenny Race and Stunt 47 11-05-2007 10:04 PM
Tire Pressures?? 10R-rugger The Out House 34 10-03-2006 09:50 AM
What pressures ya runnin' with D218's? El Diablo Performance and Tech 25 10-17-2005 09:03 PM
