2 much crankcase pressure?? - Kawasaki ZX-10R.net
post #1 of 10 Old 04-29-2008, 05:40 PM Thread Starter
zx-sik-r's Avatar
ok so i ran my 10 for tha first time after break in at tha track this weekend and came with some small issues. in the included picture the small hole above the clutch cover i noticed oil running out? it wasnt blowing it out but just oozing out a bit,also form the crankcase breather filter we put on the block? my mechanic called schnitz this morning and they said this is a common problem and it might need a evac system to drain the oil. but my mechanic think a ring might not have seated and is causing blowby. were gona do a leakdown test next week and go from there. anybody else have this problem or here about it?
zx-sik-r is offline
post #2 of 10 Old 04-29-2008, 05:41 PM Thread Starter
zx-sik-r's Avatar
oh ya we did a 1078 kit with cams and headwork(port and polish)
zx-sik-r is offline
post #3 of 10 Old 04-30-2008, 08:08 AM
FAF
Rent this space
Bigger pumping losses and windage with a bigger capacity engine , this is pretty common.
You had an Evac system before changed the breather for a filter.
If you dont want to use the intake vacuum to reduce the crankcase pressure , then you should use a catch can for the excess as it will pump oil out.
Could still be a little blow by from an unsealed ring or two though.
FAF is offline
post #4 of 10 Old 04-30-2008, 05:42 PM Thread Starter
zx-sik-r's Avatar
i figured out it needs gapless piston rings
zx-sik-r is offline
post #5 of 10 Old 04-30-2008, 05:47 PM
Speed Freak
garth285's Avatar
yep, same thing happened to my motor man, sorry to hear it happened to you as well..... gapless is a great way to go though, My motor has about 5k on her now and shes still doing fantastic!!! Was getting so much blow by coming out of my breather that it filled my belly pan up with oil..... (my breather just vents outside and down)
garth285 is offline
post #6 of 10 Old 04-30-2008, 07:24 PM Thread Starter
zx-sik-r's Avatar
man i checked out your website and its freakin sick...you do nice work bro!!!
zx-sik-r is offline
post #7 of 10 Old 04-30-2008, 07:25 PM Thread Starter
zx-sik-r's Avatar
were you noticing any kinda power loss on the upper end?? that was sumtin else that had me think about the blowby
zx-sik-r is offline
post #8 of 10 Old 04-30-2008, 08:10 PM
Speed Freak
garth285's Avatar
yeah I defiantly did notice hp loss..... after I did gapless rings and tuned with advanced timing I gained 10hp!!! Blowby does not do any good to your motor.... I have a 1051 but shes pretty strong but yeah wait till you get those rings and that 1070 will come alive.
garth285 is offline
post #9 of 10 Old 04-30-2008, 09:19 PM Thread Starter
zx-sik-r's Avatar
07 bodywork looks sweet man! i had thought about it one time but never went through with it..im a custom painter so ideas go through my head like crazy
zx-sik-r is offline
post #10 of 10 Old 04-30-2008, 09:48 PM
Speed Freak
garth285's Avatar
yeah ya know the 04-05's look great and sometimes I wish mine was still all orange but I Think once I get her painted she will look amazing... somedays im like ehhhh but when I look at her at the right angle the bike looks tight as hell..... the aerodynamics are much better and the ram air pick up is supposed to be much better then the 04-05's.... shes doin just fine with it though!
garth285 is offline
Need Left Side Crankcase cover! disjayfo0 Wanted: Buy or Trade 2 08-10-2007 09:16 AM
OK to use brake cleaner on crankcase mating surfaces?? yehzx10r Performance and Tech 11 03-19-2007 11:07 PM
Crankcase vent hose zx9rmal Performance and Tech 14 12-23-2005 12:15 AM
Crankcase cover? Perferd The ZX-10R 5 11-03-2005 08:03 AM
Holes in my crankcase?? youlose Performance and Tech 14 10-05-2005 06:52 PM
