1st trip to the dyno are these good #'s - Kawasaki ZX-10R.net
post #1 of 7 Old 05-26-2007, 03:28 PM Thread Starter
Just came from the dyno yesterday with these numbers
158.6 rwhp
79.3 rwtq
All that has been done is a Muzzy slip-on. Also the bike has 7500 miles on it. Chris Hill @ Performance Psycle in Knoxville, TN performed the work. The bike seemed to gain power all thru the rpm's and is smoother when cruising. I was told that a Kawasaki race cam would pick up about 3-4 hp and a full system would add 3-4 hp. Does this seem correct? I will post my dyno sheet as soon as possible.
Jokers05ZX10R is offline
post #2 of 7 Old 05-26-2007, 04:25 PM
MIA Ex-Mod
Tread70's Avatar
The numbers seem good but I and most don't use the numbers as gospel. Rather use it as a baseline, so that you can see what happens after other performance based mods.
Most dyno's can be off if not setup correctly or by the technician because people want to see the highest numbers possible.
If getting a custom map done, ask the tech to make it as streetable as he can unless you are using it for strictly track. You will most likely lose a few on the top end but overall it will be dead on for street riding.
Tread
Tread70 is offline
post #3 of 7 Old 05-26-2007, 05:05 PM
axo250's Avatar
Send a message via AIM to axo250
My was 160hp on Chris' dyno with a muzzy slip on and power commander with an air filter.
axo250 is offline
post #4 of 7 Old 05-26-2007, 08:17 PM
phastone's Avatar
Numbers sound good for a slip-on. I think my '04 gained 8 horse after an EVO 2 system and PC with Ivan's map. Then it gained another 9 after the thin gasket, degreed stock cams, and MD Racing map. FWIW, Ivan says you will lose more midrange than what you add on top so unless you are a dragracer/top speed guy you will be disappointed. A big number on the dyno isn't always good.
And like Tread mentioned, there are tons of variables involved with what kind of number you get from a dyno run not even including the fact that the dyno operator can make the numbers look as good or bad as they want. A dyno is a tuning device and as far as numbers go, the important thing is the gain or loss you achieve after making modifications.
phastone is offline
post #5 of 7 Old 05-26-2007, 09:34 PM
Ruthless Racing's Avatar
Images: 9
Chris does all my tuning.
My black 04 10R is at his shop now waiting on parts.
Kenny Poppell
AMA Dragbike SuperSport #1000
2007 AMA Dragbike 1000SS National Champion
2007 1000SS 1/8th ET Record Holder 5.967
Best 1/[email protected] Best 1/[email protected] Stock Wheelbase
Special Thanks:
Performance Psycle
Richies Tires
http://www.XXXRacingFuel.com
http://www.SuperbikeSpecialties.com
http://www.Tsukigi.com
http://www.CycleConceptsRacing.com
http://www.myspace.com/ruthlessracing1
Ruthless Racing is offline
post #6 of 7 Old 05-26-2007, 09:49 PM
rocketracermike's Avatar
good numbers.
rocketracermike is offline
post #7 of 7 Old 05-26-2007, 10:05 PM
bluedevil's Avatar
I have the same setup, but you should have done a baseline. I did mine with a Muzzy slip-on and used the same operator, dyno, air conditions just after that. The first run stock with a BMC filter was 151.1...second run adding the Muzzy was 156.6 if I remember right but it was a 5hp increase..so really hard to tell anything about your numbers with no baseline...sorry.
bloo
bluedevil is offline
Gap Trip luckz88 The Out House 13 09-11-2006 12:47 PM
Awesome first rally and dyno run share dyno numbers No-Mo The ZX-10R 36 05-19-2006 05:53 PM
Good Dyno info ZX10Miami Performance and Tech 1 02-02-2006 10:02 AM
Second trip to the track 99vorsi Race and Stunt 20 09-22-2005 12:28 PM
dyno tune, good or bad?? fast1 Performance and Tech 8 01-29-2005 12:36 AM
