1989 ZX10 jetting question - Kawasaki ZX-10R.net
post #1 of 7 Old 03-15-2011, 09:28 AM Thread Starter
Darren's Avatar
hi folks, k, so I just did a bunch of mods on my 1989 ZX10. Braided brakes, new levers and a Dynojet stage 1 jet kit. I have a 4 into 1 high flow exhaust and a K&N aftermarket airfilter (not the pod style) on it as well.
Question, I followed the instructions from dynojet and dropped the main jet from a 130 to a 128. Changed the needle and have the air screws set at 2 1/2 turns from being 'snug'. The outcome,,,,, it runs like garbage, spits, sputters, backfires.. its just embarasing to ride like this.
I will pull the plug and take a look but want to know if anybody else has jetted their bike and if so what size jet did you replace the main with. I was hoping the change would crisp up the throttle response a bit but definately didnt get that result, I can barely get the RPM over 4k....
Darren is offline
post #2 of 7 Old 03-15-2011, 02:37 PM
COVY's Avatar
Did the kit come with height adjustable needles?
COVY is offline
post #3 of 7 Old 03-15-2011, 03:31 PM Thread Starter
Darren's Avatar
yes it did. Per the instructions from Dynojet the clip is on the second spot
Darren is offline
post #4 of 7 Old 03-17-2011, 07:59 AM Thread Starter
Darren's Avatar
for anybody that is interested the update stands as I switched out the softer springs from the jet kit back to the stiffer stock ones and now she is running much much better. Still think its a bit lean so I am going to drop the needle clip 1 notch after work and will provide an update tomorrow.
Darren is offline
post #5 of 7 Old 03-18-2011, 09:42 PM
goldstar903's Avatar
1989 ZX10 Jetting question
Try this... it helped immensely when I put a Muzzy race motor and race carbs on my 87 ZX750R, which I still own.
http://www.factorypro.com/tech/carbt...m_engines.html
goldstar903 is offline
post #6 of 7 Old 03-22-2011, 08:08 AM Thread Starter
Darren's Avatar
last update for those that are interested. Moved the needle clip down 1 and took it for a drive. Not much different but a bit on the sluggish side so I put it back to the second slot. Adjusted the fuel mixture screws out 1/2 turn, seemed a bit better. Next in line is dropping a tooth on the front sprocket, playing with the timing and possibly degreeing the cams....
Stay safe guys and girls!!!!
Darren is offline
post #7 of 7 Old 03-22-2011, 08:35 AM
kingofkentucky's Avatar
This was my first liter bike and it was awesome. Hope you get the bugs worked out.
kingofkentucky is offline
1989 old school zx 10 depianoracing Pictures and Videos 4 12-02-2007 11:55 PM
just bought 1989 zx 10 need help depianoracing Strip 8 12-02-2007 03:28 PM
what jetting for your mains DethsZX10 ZX-9R Discussion 5 03-18-2007 09:29 AM
Jetting Necessary?? Sinisterone Performance and Tech 4 01-03-2006 05:34 PM
