16T Sprocket - How hard is it to install this? - Kawasaki ZX-10R.net
post #1 of 25 Old 06-21-2004, 09:46 PM Thread Starter
RichTJ99's Avatar
Hi,
I was curious how hard it was to install this front sprocket (16T)? Is this a DIY or is this better to bring to the dealer for a swap?
I am OK at installing things, but mostly cosmetic things is what I do :)
Thanks,
Rich
RichTJ99 is offline
post #2 of 25 Old 06-21-2004, 09:49 PM
Krazy1's Avatar
Re: 16T Sprocket - How hard is it to install this?
Originally Posted by RichTJ99
Hi,
Thanks,
Rich
As long as you have tools to do so it is very easy.
Krazy1 is offline
post #3 of 25 Old 06-21-2004, 09:52 PM
Andy's Avatar
Images: 25
Installing the new sprocket is easy, getting the old one off is a B.
I had to get a machanic buddy with an air ratchet to help get it off. Once its loosened its all a piece of cake after that.
Andy is offline
post #4 of 25 Old 06-21-2004, 10:16 PM
Big Daddy's Avatar
Images: 38
Yeah what PW #1 said :P
Big Daddy is offline
post #5 of 25 Old 06-21-2004, 10:40 PM
lucifer's Avatar
Hate to be specific, but an impact gun is what you need, not an air ratchet.
An air ratchet will not work to remove a countershaft nut, so don't ask your mechanic buddy using that terminology. I am sure that was what Andy meant anyway. :?
Black ZX10R, honda CRF150 Supermoto racer
If you ain't slidin', you ain't ridin'
lucifer is offline
post #6 of 25 Old 06-21-2004, 10:45 PM
I loosened it with a breaker bar while sitting on the bike. its all you need.
live on the edge.
crazyman1 is offline
post #7 of 25 Old 06-21-2004, 11:40 PM
44
44's Avatar
you gonna put the bike in the first gear (if you are alone and there is nobody to help you but ı dont recommend this method you can damage your transmission, you better have somebody else sitting on the bike and applying rear break.)
take the wrench (ı dont remember the size though) stick on it firmly and hit the wrench with a hammer (at least 500gr) to creat an impact effect.
dont try to do it like you are taking off a tire nut. just keep hitting with the hammer. after a couple of hits you will see it.
ıt will loosen. thats the only way with the conventional tools. if you have professional tools like an impact gun it is much more easier.
but dont forget the apply rear break firmly.
WINNERS NEVER QUIT, QUITTERS NEVER WIN
YOU GET WHAT YOU DESERVE
44 is offline
post #8 of 25 Old 06-22-2004, 09:52 AM
Don't forget to flatten out the bended washer! Makes it a bit easier. :)
Mal
'12 ZX-14R
'12 ZX-10R
65+ and medicated
zx9rmal is offline
post #9 of 25 Old 06-22-2004, 03:02 PM
JLove's Avatar
Just got my 16T last week. I tried to get the stock one off and I had to give up or risk scratching the hell out of my frame. The nut is a 27mm nut (HUGE) and you will need a deep socket to reach in there. You will also need a big socket wrench. Its not obvious if it comes off counterclockwise or not, but it is counterclockwise.
I am not sure what the bent washer is that keeps being mentioned.
I need to get out to the store to get a deep 27mm socket and then I will try again.
2004 ZX-10R black (sold)
2008 CBR1000RR
2011 ZX-10R ABS Black
#51 NESBA, TPM, Absolute
JLove is offline
post #10 of 25 Old 06-22-2004, 03:21 PM
Big Daddy's Avatar
Images: 38
a shortish extension can be used as well, perhaps 2".
There is a washer(per the parts diagram) that fits underneath the 27mm nut and once the nut is torqued to spec you will need to bend a portion of the washer over the flat part of the nut to aid in not letting the nut backoff.
Help w/ Euro signal install wfobusa The ZX-10R 3 05-16-2004 09:32 AM
sprocket? pmkin10r The ZX-10R 1 04-16-2004 02:38 PM
BREAK IN PROCEDURES FOR MAX HP TRUE OR FALSE? zixxer Archives 29 11-01-2003 12:43 AM
