16 Tooth Sprocket Mod - Kawasaki ZX-10R.net
post #1 of 15 Old 08-24-2006, 12:00 AM Thread Starter
modpup's Avatar
well i finally did the 16 tooth mod and put a k & N air filter on my 2006 and you guys were right, now the bike has some serious bottom end. I haven't ridden much since i did it so i can't give a great comparison as of yet. But i do notice quite a difference in how the bike accelerates. I am very pleased.
If you guys read my roll-on story with the 2006 gsx-r you will know why i did the mod. My buddies bike jumped me and i couldn't catch him. I was totally pissed off. I am waiting to race again, i think its going to be a different outcome.
This winter i want to get a full race akrapovic system with power commander and TRE. But money isn't plentiful all the time.
Thanks for the advice to go with this sprocket.
Oh yeah, and for anyone that has ever tried to get the nut off the counter sprocket on this bike will know how fun that was. It might as well have been welded on, my buddy and i tried for an hour with a decent impact and finally a 3 foot snipe and strong arm broke it loose.
I guess i need a speedo healer now, does anyone know where to get one, how hard is it to install and how much one costs?
modpup is offline
post #2 of 15 Old 08-24-2006, 12:05 AM
Post Whore
Older Guy's Avatar
Check the sponsors...
15 minute installation....
It's a snap...
Older Guy is offline
post #3 of 15 Old 08-24-2006, 07:41 AM
It's a snap...
BUT if you decide to re-route the SpeedoHealer cable once you've already snapped the white connectors on the SpeedoHealer cable to the black connectors on the bike (this will make sense when you do the install), and you need to disconnect the connectors to do the re-route, be very careful to pull only on the plastic connector body and not at all on the wires leading into the connector. Those wires can slide out of the connector body with unexpected ease, and the delicate nature of the female ends by which they attach to the connector body makes it nearly impossible to repair such a problem! If you can't fix this problem without damaging the delicate female ends (I couldn't), you have to buy a new cable.
I hope this helps you avoid my $40 mistake! :headshake
GD
Green Dude is offline
post #4 of 15 Old 08-24-2006, 09:52 AM
Speedohealer - Cal-Sportbike is the US importer (and a site sponsor, so deal with them through this site), their website page for the SH is: http://www.calsportbike.com/sh , and Speedohealer's website is: http://www.speedohealer.com . You want or will need to order the universal kit, lists for $90, and search here for posts by me and sewman for some how-to instructions.
TRE - I say do it now, it's cheap (TRE-009, $60, http://www.ivansperformanceproducts.com/tre.htm ) and for the 06 most have found it does make a diff down low. Again, if you are going to do it, search here for 06 TRE install instructions, there are some things to watch out for.
ctjackster is offline
post #5 of 15 Old 08-24-2006, 01:10 PM
You may want to find out in advance whether you need a Power Commander to properly use a TRE on the '06. Again, I found out the hard way (so many personal failings revealed in this little thread . . . :headshake ) that the TRE for the '04-'05 also requires (I heard this from Ivan's mouth) use of a Power Commander to correct low-rpm fuelling issues brought on by the TRE. Ivan's website doesn't mention this issue re: any of the ZX-10R TREs, but only the Suzuki TREs are described as "smart" and not requiring any fuel injection moods to work properly, so the '06 likely needs a Power Commander . . . Maybe a call to Ivan is in order before your order is in.
I thought the TRE mod wouold be a nice, low-cost mod for my '05, but finding out after I had the TRE in hand that I needed to spend several hundred dollars to make it work right didn't exactly sweeten the deal.
Forewarned is forearmed!
GD
post #6 of 15 Old 08-24-2006, 05:56 PM Thread Starter
modpup's Avatar
thanks guys for your help, i appreciate all your opinions.
modpup is offline
post #7 of 15 Old 08-24-2006, 05:58 PM
GD
NO POWERCOMMANDER REQUIRED FOR TRE ON THE 06 ZX10, per Ivan's own posts . . . it's a different animal than the 04-05 TRE
post #8 of 15 Old 08-24-2006, 06:04 PM
you dont need a power commander for the TRE mod on the 06 i have it and you should get it. it does make a very noticible difference
T3MPO is offline
post #9 of 15 Old 08-25-2006, 01:20 PM
Dagnabbit! Lucky '06-owning so--and-so's!
GD
post #10 of 15 Old 08-25-2006, 08:27 PM
Images: 14
whats the tre mod, im new to the zx 10 world i just bought a new 06r1 but i might be changing to a 07 10r in blue.
99zman is offline
06 10r 16 Tooth Sprocket TX06'10r The ZX-10R 19 04-04-2006 08:15 AM
16 Tooth OEM Sprocket '04/'05 BackMarker Parts, Gear and Accessories 10 02-14-2006 09:13 PM
16 tooth sprocket JOHNH Vendor Deals 1 09-15-2005 10:32 AM
18 tooth front sprocket maze Performance and Tech 15 01-18-2005 10:34 AM
15 tooth sprocket? Floyd The ZX-10R 7 07-14-2004 10:14 AM
