14k redline?? - Kawasaki ZX-10R.net
post #1 of 30 Old 01-25-2011, 09:53 AM Thread Starter
09zx10miami's Avatar
14k redline??
Just curious to see if any of yall have bumped your redline up to 14k and is your head stock or worked....I see many people getting there redline bumped up to 13,650 when they get there ecu flashed but anyone go higher?? The kit race manual says you can do 14k but i'm not sure about reliability ...
09zx10miami is offline
post #2 of 30 Old 01-25-2011, 10:13 AM
KIRK_ADAMS's Avatar
subscribed...
KIRK_ADAMS is offline
post #3 of 30 Old 01-25-2011, 11:56 AM Thread Starter
post #4 of 30 Old 01-25-2011, 02:25 PM
KIRK_ADAMS's Avatar
post #5 of 30 Old 01-25-2011, 02:33 PM
Speed Freak
garth285's Avatar
I'm revving to 13,700 on stock valve springs
garth285 is offline
post #6 of 30 Old 01-25-2011, 02:59 PM Thread Starter
Whats the stock redline on the gen 4?
post #7 of 30 Old 01-25-2011, 03:19 PM
Speed Freak
garth285's Avatar
13,700 :-)
garth285 is offline
post #8 of 30 Old 01-25-2011, 03:54 PM
dsabat's Avatar
Without port work and cams, there's no power to be gained by spinning that high on a Gen 1-3.
I've run my NA motor to 14K with HD valve springs and stock rods with no issues, as long as your clearances are correct you'll be fine. 55mm stroke keeps piston speed within reasonable limits.
dsabat is offline
post #9 of 30 Old 01-25-2011, 04:08 PM
KIRK_ADAMS's Avatar
What about if you play with cam timing...
post #10 of 30 Old 01-25-2011, 07:26 PM
Really?
My zx10 has NO over rev. It makes peak power on the rev limiter. The only reason it doesn't make more power is because it runs out of rev limit.
Patrick is offline
Redline motor oil 06BLK10 Vendor Deals 1 08-18-2007 01:05 AM
Redline Race oil 06BLK10 Performance and Tech 1 08-16-2007 10:33 PM
Bike won't redline... Lakers08 Performance and Tech 29 07-24-2007 07:39 PM
got to redline finally Wind Draft The ZX-10R 18 02-20-2007 10:06 PM
Redline 2WT Oil???? Ruthless Racing Performance and Tech 3 07-31-2006 04:28 PM
