10r valve shims - Kawasaki ZX-10R.net
post #1 of 7 Old 11-27-2008, 04:14 PM Thread Starter
sincitymarv's Avatar
10r valve shims
A big hello to all,
i'm new to the site and need a bit of info. i've had a search but can't find anything that covers it, sooooooo
would any of you know if the valve shims from a 2003 zx6r(b1h) are the same as the ones in the 04 10r.........cos i've just checked the clearances and a few are out of tolerance, now i'll prob be able to swap a few about but i've also got an old 636 motor lying about that if need be i can use the shims out of
Thanks in advance
Ozz
sincitymarv is offline
post #2 of 7 Old 11-27-2008, 04:19 PM
MIA Ex-Mod
Tread70's Avatar
I want to say yes, but I don't have a reference here to go by. I believe all brands choose and stick with the same shim so they wouldn't have to buy multiple types of shims. You may be able to look online for shims for each motor and year and see if they are the same product number. Just an idea, also......... and hope you stick around for a while with us.
Tread
2004 PBO zx10-r pazzo, seat cowl, yoshi Ti TRS bolt on, PC3, Speedo-Healer, Hyperpro, Braided lines, 16-40, Sato sets, ZG dark screen, and more.
Tread70 is offline
post #3 of 7 Old 11-27-2008, 09:24 PM
bugman53's Avatar
yes they are the same
High Velocity Cycles 2005 Ti ZX10R
Greeensboro NC
bugman53 is offline
post #4 of 7 Old 11-28-2008, 09:51 AM
sextaafondo's Avatar
As long as they are 7.48 mm diameter they will fit.
sextaafondo is offline
post #5 of 7 Old 11-28-2008, 02:50 PM Thread Starter
Thumbs up
Thanks guys, thats the peace of mind i was after.
Cams out today and swapping shims about this evening so hopefully back together tomorrow, have taken pics of everything to help remind me where it all goes
Ozz
post #6 of 7 Old 11-28-2008, 03:26 PM
TKZX's Avatar
Images: 11
Post
This is a step by step document on how to do Valve Adjustments write by a gentleman called Richard McDonald
I hope it will be a good help.
http://www.themcdonalds.net/~themcdo/richard/index.php?title=ZX-6R_Maintenance:_Adjust_Valve_Clearances
TKZX is offline
post #7 of 7 Old 11-28-2008, 04:00 PM Thread Starter
Yep cheers, have seen that guide before. When i had my zx6r, i found it handy when valve clearance time came around, the photos ive taken this time are just to refresh my memory as to where all the wiring and pipes go.......who knows they might even be of help to someone in the future...........i mean...like someone else needing help...not someone from the future coming back in time to find out how to do valve clearances...lol
Slipper Clutch Adjustment Shims anthonyzx10r2008 The ZX-10R 4 11-11-2008 10:50 AM
Ride Height Shims ZX-10R_04 Performance and Tech 1 08-01-2007 01:05 PM
shims rocketracermike Performance and Tech 2 07-29-2007 06:11 AM
Size shims for clutch springs? salsa1 Race and Stunt 3 05-10-2006 10:21 AM
Buckets, shims and a block head 1killer1liter Performance and Tech 18 04-11-2006 08:33 PM
