10r owner 636 sprocket Q??? - Kawasaki ZX-10R.net
post #1 of 3 Old 05-06-2006, 11:52 PM Thread Starter
10R-rugger's Avatar
Ok all ,I have a 10r and have changed like 7 front sprockets before. tonight I tried to change my friends 2005 636 front sprocket -1 tooth. it was a PAIN to get the stock sprocket off from around the chain and the back tire was full loose.
Ok i then changed it to a 14t which is -1. JT sprocket.
OK NOW........1 side is smooth and one side had an indent type thing with #'s on it. when i put it on the the numbers showing like ALL sprockets usually go..the chain seemed to pinch in and not look correct.
so i switched it back to the indent facing IN with the Flat side facing OUT.
it seemed good to go. we drove it around the block a few times. everything ok.came back adjusted the chain and he went home. NOW,
*** HE JUST called and loved the extra torque in 3rd-4th gear
BUT he says there is some whining noise now that started???
--could this be the chain too tight?
-- is the sprocket on backwards?
ANY Other advise? i do not want anything to happen to his motor or anything because of my mistake!!
please let me know
post here or email me:
[email protected]
10R-rugger is offline
post #2 of 3 Old 05-07-2006, 10:02 AM
sneaky's Avatar
Did you use a factory sprocket, if not and it is aftermarket then that is the answer.
Most stock sprockets have a rubber damper on them to keep the noise down, most aftermarkets dont have this rubber damper thus when you change them out they tend to make a whinning noise.
This is why I always pay a little more and just change out my rear instead.
sneaky is offline
post #3 of 3 Old 05-07-2006, 01:26 PM Thread Starter
10R-rugger's Avatar
sprocket
ok I appreciate the reply.
but I have a vortex on my 10r now and it is aftermarket and does not make any noise at all.
I just want to make sure that I have in on the right side out.
is there anything bad that can happen if it is on backwards?
i am going down there today to ride it and listen to it for him.
any advise appreciated.
thanks!
636 sprocket 10R-rugger ZX-6R & ZX-6RR Archives 0 05-06-2006 11:51 PM
06 10r 16 Tooth Sprocket TX06'10r The ZX-10R 19 04-04-2006 07:15 AM
Who's coming to the 636 from the 10R? SuicideMachine ZX-6R & ZX-6RR Archives 16 03-16-2006 10:15 AM
Are the 2005 636 and 10R wheels interchangable? SuicideMachine ZX-6R & ZX-6RR Archives 7 08-20-2005 11:41 PM
RedElk's ZX10R Ride and Adventure review swft The ZX-10R 11 03-11-2004 01:24 PM
