10R brake problem... - Kawasaki ZX-10R.net
post #1 of 89 Old 01-04-2006, 08:13 PM Thread Starter
10R brake fluid??
So I read about how the brake is supposed to be bad and should change to brembo or nissin master cyl. Well I talked to a former GP racer who is now a kawi mech and he said it is a stock fluid problem. He says the fluid heats up and boils so by changing the fluid it will kill the problem, that plus the new lines...
So?
Perferd is offline
post #2 of 89 Old 01-04-2006, 08:14 PM
10 speed's Avatar
im going outside with a stick of dynomyte
10 speed is offline
post #3 of 89 Old 01-04-2006, 08:16 PM
Green Hippie
treyzx10r's Avatar
I'm running synthetic Motul fluid and ss lines the Brakes work fine even on super hot August days at the Track
VAE VICTUS!
treyzx10r is offline
post #4 of 89 Old 01-04-2006, 08:16 PM Thread Starter
Why the stick of TNT?
Perferd is offline
post #5 of 89 Old 01-04-2006, 08:19 PM
sneaky's Avatar
That is only part of the prob, the other part say you hvae done those upgrades is once the fluid gets hot it tends to bleed by the seals in the master cylinder and cause brake fade.
sneaky is offline
post #6 of 89 Old 01-04-2006, 08:21 PM
Green Hippie
treyzx10r's Avatar
not having a problem with that at all
VAE VICTUS!
post #7 of 89 Old 01-04-2006, 08:21 PM Thread Starter
I just wanted to hear the take on the fluid....heat boil comment...From what he said you change the fluid it wont get nearly as hot. That being said the seals would not become a problem...
Perferd is offline
post #8 of 89 Old 01-04-2006, 08:24 PM
Green Hippie
treyzx10r's Avatar
okay
VAE VICTUS!
post #9 of 89 Old 01-04-2006, 09:39 PM
phastone's Avatar
So?
I tried everything. I changed the fluid, no change. Then the lines, got a little better. Then the pads, more bite but no real change in lever travel. Nothing kept the brakes from becoming less effective and the brake lever squashing my fingers after a couple sessions at trackdays. I'm doing the 636 mod this weekend. Hopefully, this will fix the problem come springtime.
phastone is offline
post #10 of 89 Old 01-04-2006, 09:47 PM
Green Knight's Avatar
Send a message via MSN to Green Knight Send a message via Yahoo to Green Knight
I used the NAPA DOT 4 fluid with no problems at all on my 6RR. You can feel it heat up and expand during the first use of the breaks but thats it. I don't have any fade problems. I'm using Bremo pads with SS lines.
Green Knight is offline
Replacing Brake Lines, Fluid, and Bleeding zx102nv Performance and Tech 20 10-21-2009 05:58 PM
10R Brake Upgrades Tito Performance and Tech 32 12-10-2005 07:16 AM
Clutch Cable wear (potential problem for all 10R owners)! RichTJ99 Performance and Tech 25 01-23-2005 09:19 PM
Replacing Brake Lines, Fluid, and Bleeding zx102nv How To... 1 01-10-2005 03:27 PM
RedElk's ZX10R Ride and Adventure review swft The ZX-10R 11 03-11-2004 01:24 PM
