10R 2008 engine on a ZX10r 2006-07 - Kawasaki ZX-10R.net
post #1 of 43 Old 12-22-2010, 02:00 PM Thread Starter
Oengus's Avatar
hello there
do you know guys if it's possible to install the engine of a 10r 2008 on a 10r 2006 ? I know that the engines are similar, and it's possible to install it, but I wonder if I can use the ECU and the electric wiring of the 2006 for that engine.
my only concerns are about the ignition timing...do you know something about it ?
thanks
Claudio
Oengus is offline
post #2 of 43 Old 12-22-2010, 02:29 PM
dsabat's Avatar
I dont' know for sure, but I think that a 2008 engine will fit in a 2006 chassis. Externally they look the same, other than clutch cover appearance.
dsabat is offline
post #3 of 43 Old 12-22-2010, 10:01 PM
Gen2 Ripper
neverendingmods's Avatar
You'll need a way to control the extra 4 injectors on the 08 motor. I have seen the swap done before, but I believe at least the ecu and most of the back half wire harness from the 08 was used on the 07 bike(for the extra injector control).
neverendingmods is offline
post #4 of 43 Old 12-23-2010, 01:02 AM
Shorty's Performance
madnessracing's Avatar
You will need to get the complete wiring harness with sensors and ecu too
madnessracing is offline
post #5 of 43 Old 12-23-2010, 05:42 AM
Dont mess wit White Ninja
abzx10r's Avatar
Do you think the air box is the same?
abzx10r is offline
post #6 of 43 Old 12-23-2010, 08:41 AM
dsabat's Avatar
Or you could just use the throttle bodies from the '06.
dsabat is offline
post #7 of 43 Old 12-23-2010, 10:06 AM
DAXENOX's Avatar
Images: 11
Send a message via Skype™ to DAXENOX
Originally Posted by Oengus View Post
hello there
thanks
Claudio
MA CHE STAI COMBINANDO , MINKIA IN AMERICA TI TROVO?
DAXENOX is offline
post #8 of 43 Old 12-25-2010, 10:58 AM
Send a message via MSN to Chris79
Is it really a direct bolt on? No mods needed if letting 06 throttle bodies?
Chris79 is offline
post #9 of 43 Old 12-25-2010, 12:52 PM
Dragone's Avatar
Images: 11
or maybe using the kit ecu in this application?
Dragone is offline
post #10 of 43 Old 12-25-2010, 01:55 PM
filthy phil's Avatar
what about exhausts? if a g3 exhaust'll work on my g2 that will greatly ease my search.
sorry to thread jack and merry x-mas folks
filthy phil is offline
parting out 2006-2007 zx10r engine samizx7 Parts, Gear and Accessories 7 06-15-2012 12:41 AM
2006 zx10r engine internals slamdcoop Performance and Tech 6 06-09-2009 02:54 PM
2008 6r brake Calipers on 2006 zx10r lowkey420 The ZX-10R 5 05-05-2009 03:26 PM
PC3: 2008 ZX10R: 2006/07 *2* PC3 will work on 08 ZX10R Vonstallin Performance and Tech 30 07-05-2008 11:16 AM
Galfer MotoGP Brake Line Kits - Kawasaki ZX10R (2006-2008) anthonyzx10r2008 General Motorcycle Discussions 4 02-21-2008 01:31 AM
