100w headlamps on the gen1? - Kawasaki ZX-10R.net
post #1 of 7 Old 08-19-2008, 03:42 AM Thread Starter
EvoNinja's Avatar
So here's the deal, i want to try to get 100w (55w stock) bulbs on both high and low beam on my gen1. Problem is as expected as soon as i hit the high beam the 10A fuse blows up. It works fine with the low beam at 55w and the high at 100w, but not both.
So the question is, if i switch the stock 10A fuse to a 15A or 20A will it work or will i risk blowing the electrical system all together?
ZX-10R
>> scary fast
EvoNinja is offline
post #2 of 7 Old 08-19-2008, 08:43 AM
ninja44's Avatar
100W bulbs will melt the harness! The wires, connectors and housing is not meant to take that much heat which is why your fuses are blowing.
Sean
08 10R Pearl Wildfire Orange
Akra slip on W/Link Pipe, Ohlins R&T Forks, Ohlins 46PRXLS, Attack Rearsets, Guhl ECU Reflash, Ivan's Block Offs, Pazzo Levers, Goodridge Carbo Brake Lines, Vesrah RJL Pads, Riflemans 1/5 Throttle Insert, R & G Sliders & Engine Guards, Puig Z Screen, Puig Hugger, Evotech 1/4 turn gas cap
ninja44 is offline
post #3 of 7 Old 08-19-2008, 10:24 AM
Drain Fade's Avatar
Try HID....it's less wattage and better output than a 100watt anyway.
~Drain Fade
'06 Ebony Black, Supersonic Sport Tourer
A ton of shit....I want the farkles of a Gold Wing on a 150HP bike just over 400lbs ;)
Have a VFR, ZX9R or ZX10R, check out http://drainfade.com
Drain Fade is offline
post #4 of 7 Old 08-20-2008, 12:57 AM
Newfie Bullet
craig_sez's Avatar
Images: 34
Dont forget,get a digital ballast....I can run both hi and low on less pwr that i can run a low normal bulb....
Dont know how much difference it would be if you got the 55w set up over the 35w..I know i get flashed during the day with the 35w and at night i can run with my tinted visor down and still see...HID"S are the way to go..try these guys..Ask for leif..Quality stuff,plug and play and you can even get a life time warrenty..14 of use from canada had them made..luvem..
http://www.ddmtuning.com/hidkihidbuhi.html
craig_sez is offline
post #5 of 7 Old 08-20-2008, 01:43 AM
if you want really bright get DDM tuning 50watt HID kit. but if you want a colored look go higher. i got 8000k and its usually a little bit bluish but when its 55w its really white. so if you want more blue go 10-12k and purple 16-18k yellow would be 3k. but DDM tuning is the best i've found and they look great. there is a couple photos. two photos show the difference between stock and HID. and let me tell you these things are bright.
ID:	75640   Click image for larger version
ID:	75641   Click image for larger version
evan_880 is offline
post #6 of 7 Old 08-20-2008, 04:59 AM
thrill's Avatar
100 watt will cook the generator
Bill - GI Pro, Hindle slip on, Smoked screen, ZX14 brakes.... Well, you feel lucky, punk? You shouldn't, this is a 10R
thrill is offline
post #7 of 7 Old 08-20-2008, 06:13 AM Thread Starter
EvoNinja's Avatar
Well HID it is then.
I was worried about the harness and the generator itself, seems like theres no getting away from HID in my case.
ZX-10R
>> scary fast
EvoNinja is offline
PIAA Headlamps ZX10man Performance and Tech 10 02-06-2008 02:08 AM
Stick with gen1? Mrsittter The ZX-10R 82 11-29-2007 12:41 PM
08 10R Gen1 vs Gen2 Deer Elk The ZX-10R 82 10-20-2007 04:27 AM
Headlamps danno46 The ZX-10R 26 07-21-2005 10:22 AM
100w bulbs? Ground Zero The ZX-10R 21 10-03-2004 05:49 AM
