Gen 2: 2006-2007 -1/+2 speedometer readings. What % is it off? - Kawasaki ZX-10R.net
post #1 of 24 Old 09-21-2012, 05:07 AM Thread Starter
Ok i just went down one and two up and i was curious what everyone had their speedohealers set to? I dont have one yet so i gotta calculate in my head while i ride lol
Thanks in advance!
Ls1Powerz is offline
post #2 of 24 Old 09-21-2012, 07:31 AM
SkyDork's Avatar
Shooting from the hip, I'd say your in the 12-15% range. All stock, the speedo is off about 8-10%. You're going off quite a bit more than that. The most accurate way to check and calculate your error is with a GPS that shows speed or using the VASCAR method of timing yourself over a given distance. Then you'll know what kind of error you have based on your exact setup.
#WordCrimes
SkyDork is offline
post #3 of 24 Old 09-21-2012, 07:45 AM
kman0066's Avatar
I think when I ran that setup on my Gen 2, I had my speedohealer set at 12.5% to get it pretty close. Try that and go out with a GPS and see how close that gets you.
kman0066 is offline
post #4 of 24 Old 09-21-2012, 07:53 AM Thread Starter
I thought that with just a -1 front it was 12.2% roughly... shouldn't it be off more now?
post #5 of 24 Old 09-21-2012, 08:00 AM
SkyDork's Avatar
Not sure where you got the 12% figure with just -1, but it's not that high. but each bike will be slightly different. The only way to know accurately is to measure it on your bike.
#WordCrimes
SkyDork is offline
post #6 of 24 Old 09-21-2012, 08:02 AM
Waterfreak66's Avatar
On my gen 3, -1 was -12.1; with -1/+2 it is -15.5.
Waterfreak66 is offline
post #7 of 24 Old 09-21-2012, 08:35 AM Thread Starter
I'm gonna try to read my GPS at 45mph then I guess and hope I don't wreck lol
post #8 of 24 Old 09-21-2012, 08:46 AM
Run it at 60 on the GPS for better accuracy.
post #9 of 24 Old 09-21-2012, 08:54 AM Thread Starter
I don't have a mount so I'll have to hold my phone and use it :(
post #10 of 24 Old 09-21-2012, 09:10 AM
I use Velcro :-)
Gen 4: AFR Readings With Ram Air Danko The ZX-10R 3 05-08-2012 09:13 PM
Strange FI readings leemille Performance and Tech 3 04-14-2012 02:43 PM
Gen 1: TPS readings zuhayr Performance and Tech 5 10-05-2011 12:15 PM
Erratic Speedo Readings pls Help Larry Grogan Performance and Tech 13 08-15-2010 08:25 PM
Voltage Readings coach Performance and Tech 0 02-23-2006 12:34 PM
