-1 +2 and other - Kawasaki ZX-10R.net
post #1 of 3 Old 08-27-2014, 01:53 PM Thread Starter
noahrr25's Avatar
-1 +2 and other
So I did the swap...insane difference, power wheelies at 5k now instead of 7-8k... gotta be careful!! Freaking animal.
Now I have an issue. I rode the back last week, then she went on stands. Everything was fine, no issues. Rode her for the first time today after doing the swap and when I am slowly twisting the throttle it acts like it isn't getting enough gas and forward movement is jerky. When I open her up, full throttle it goes away and acceleration is even and consistent. Any ideas?
2006 Black ZX10R : Galfer braided steel lines, Brembo rcs19 Master w/ Brembo reservoir and shorty lever, CRG RC2 Shorty clutch lever, Shogun bar ends, K&N Air/Oil filters, Motionpro Throttle cables, Nissin zx14 calipers, carbon lorraine pads, Galfer Wave rotors front/rear, -1+2 vortex, Black EK chain, Speedo Tuner
Soon to be added : APE CCT
Wanted for future : Woolich ECU, Attack rearsets, 35k HIDs, TIForce Slipons, APE Tit. retainers, Rifleman throttle mod, Smog blocks
noahrr25 is offline
post #2 of 3 Old 08-27-2014, 02:28 PM
SkyDork's Avatar
Did you put a new chain on with the sprockets? What else did you touch when changing the gearing?
I'd speculate that you reused a worn chain with the new sprockets and you're now getting some part-throttle driveline lash. That or your chain freeplay is incorrect. Assuming you didn't mess with anything else on the bike when doing this.
#WordCrimes
SkyDork is offline
post #3 of 3 Old 08-27-2014, 09:08 PM Thread Starter
noahrr25's Avatar
New chain new sprockets. Have 1.25" free play while sitting on it, checked the gas line as I had the tank off installing my speedo tuner and it is straight. Just don't know why this showed up out of the blue? I had my work checked by a motorcycle shop as this is the first time I have ever worked on anything mechanical.
noahrr25 is offline
