-1 +2 is CRAZY !!! - Kawasaki ZX-10R.net
post #1 of 111 Old 01-15-2011, 03:32 PM Thread Starter
jm981_4343's Avatar
-1 +2 is CRAZY !!!
I changed my chain and sprockets today.
acceleration is crazy, this will take some time to get use to until then
I'll be the WHEELIE KING!!
jm981_4343 is offline
post #2 of 111 Old 01-15-2011, 04:23 PM
kawsquid23's Avatar
hahaha nice, ive always wondered what changing the gearing would be like. im going to get some for the track to run different set ups but for the street w my mods i like the stock gearing but 520 coversion did a lot on its own.
kawsquid23 is offline
post #3 of 111 Old 01-15-2011, 06:12 PM
Teeks's Avatar
If its too nuts, just get a stock front sprocket for $20, and leave it as +2 in the rear
Teeks is offline
post #4 of 111 Old 01-15-2011, 06:33 PM
Gen2 Ripper
neverendingmods's Avatar
Yep, -1 +2 rocks. The speedo jumps in 20mph increments because it can't keep up.. Just make sure you let the tire fully warm up before you go WOT in 1st or 2nd gear cause it will break loose.
neverendingmods is offline
post #5 of 111 Old 01-25-2011, 09:09 PM
BigCat for Prez!
BigCat10R's Avatar
when changing the gears do you have to buy a different chain or does the chain not matter?
BigCat10R is offline
post #6 of 111 Old 01-25-2011, 09:36 PM
RDLYN13000's Avatar
Images: 38
How did changing to a 520 do anything if you didnt change gearing? 520 is just a thinner chain that weighs slightly less
RDLYN13000 is offline
post #7 of 111 Old 01-25-2011, 09:53 PM
Teeks's Avatar
Bigcat yes it is best to change your chain with your sprockets, unless they have fairly low miles, you also need to make sure the chain pitch matches the sprockets.
RDLYN, +1. I will literally guarantee you will not notice any difference between a 525 and a 520 conversion, its all in your mind.
Teeks is offline
post #8 of 111 Old 01-25-2011, 09:58 PM
italicizedsponge's Avatar
i have -1/0 right now and i can barely notice a difference, I'm thinking about switching back to stock this summer since i mostly only do top end runs.
italicizedsponge is offline
post #9 of 111 Old 01-25-2011, 10:12 PM
zx racer's Avatar
i ran -1/0 for a while and i noticed a lil more pep down low but when i put a +2 on the back it really woke it up.
zx racer is offline
post #10 of 111 Old 01-25-2011, 10:13 PM
Guilty by association
CP10R's Avatar
I used to run that ratio, but changed to just -1 in the front stock rear. I thought it was too jumpy and i dont need that much help to do a wheelie.
CP10R is offline
This is some crazy ISH!!! Crazi Adult Content - Photos / Videos - N.W.S. 7 09-03-2009 10:10 PM
What would you do? Crazy. BrandensDogs General Motorcycle Discussions 1 05-12-2008 09:48 PM
sue crazy.. rocketracermike The Out House 1 02-14-2008 07:37 PM
Would I be crazy to get rid of the 10 for this? 06Neenja The Out House 20 08-13-2007 05:33 PM
