09 zx10r Immobilizer ???? - Kawasaki ZX-10R.net
post #1 of 2 Old 12-29-2010, 02:57 PM Thread Starter
09zx10miami's Avatar
I purchased my 09 zx10 with 500 miles on it. I was never told by the previous owner that it had a immobilizer on it...The problem that i'm running into is i tried to connect a race ecu using the subharness and my fuel pump doesn't turn on. I went through everything and couldn't figure it out... I connected
12v directly to fuel pump and the bike started up and ran fine... I found out now it has a immobilizer and that is whats causing the fuel pump not to turn on the fuel pump being that i'm trying to use a race ecu...Does anyone know how I can take of this immobilizer system off the bike? Do I just disconnect it or do I have to run resisters or something of the sort..I'm trying to avoid running a relay to make the fuel pump work.
09zx10miami is offline
post #2 of 2 Old 12-29-2010, 08:25 PM Thread Starter
Ok I figured it out thanks.....
New Sport Rider out today! 08 ZX10R on the Cover! 07 ZX10R Moding gone mad story! JimmyJam The ZX-10R 60 02-26-2008 11:34 PM
Immobilizer NINJA191 The ZX-10R 6 02-24-2007 08:49 AM
Did Kawi cut the Immobilizer from the 06 too? IITravel The ZX-10R 1 01-20-2006 04:24 PM
Can the UK model ZX10R's immobilizer fix on those without? kwakzx10r The ZX-10R 10 09-15-2004 06:53 AM
Fuel Injector Immobilizer LED Indicator DerrickLHarris The ZX-10R 10 04-29-2004 01:59 PM
