Gen 3: 2008-2010 09 ZX10 wont start need some help - Kawasaki ZX-10R.net
post #1 of 4 Old 08-25-2012, 07:57 PM Thread Starter
JustSprayIt's Avatar
So my bike was in a accident and it ripped off the nose of the bike since then it wont start the bike cranks but theres no fuel or spark when you turn the key the pump dosent prime or anything ... I replaced the tip sensor and any fuses that were blown the cluster is to messed up to read but a shop let me use one and it said code 39 which is a ecu issue theres continuity from both ends of the ecu signal wire at the cluster and ecu. Should I replace the ecu or has anyone ever had a similar issue
thanks in advance
JustSprayIt is offline
post #2 of 4 Old 08-27-2012, 01:35 AM
tasos's Avatar
Check that the pins on the ecu wires are all plugged-in, making good contact with ecu when connected.
tasos is offline
post #3 of 4 Old 08-27-2012, 04:55 PM
Check the imobilizer wires and antena
bikeserv is offline
post #4 of 4 Old 08-28-2012, 06:43 AM
maXmood's Avatar
swap ecu with a friend that has the same bike, check if it works that way.
check your wires going to the injectors and immobilizer and make sure they're all working fine.
Learning stage...
maXmood is offline
Gen 3: HELP..!! GEN 3 wont start.... KIRK_ADAMS Performance and Tech 18 10-18-2011 10:04 PM
04 10r wont start... SoRicey General Motorcycle Discussions 4 04-02-2011 08:12 PM
Help 05 zx10 wont start FreeAgent General Motorcycle Discussions 13 03-20-2011 01:18 PM
'08 ZX10 would only start with the charger hooked up, and now wont run at all. Cocky Rooster Performance and Tech 19 09-09-2010 08:49 AM
Sometimes wont start NZ_ZX10R Performance and Tech 3 01-21-2008 11:26 AM
